Question about Brother Sewing Machines
Brother pc 8500 sewing machine-- the balance wheel
The balance wheel is squeaking when moving forward, is the something I need to worry about
    Problem Solver:
  • 10 Answers
The upper shaft is probably binding a little on the bushing. Take it to your local Brother Dealer, this is not uncommon on this machine.
I have 25 years experience on Brother machines
Posted on Jun 30, 2009
I have a Brother sewing machine,model XL 6562, unsure of age, it's older. Today it only sews in reverse, cannot make it go forward. Help!!
well reverse button must be stuck. Try turning wheel to move forward and setting the stitch, like to zigzag. Oil it good, old machines get "thirsty".
Aug 01, 2017 | Brother Sewing Machines
Unlock brothers LS2125i sewing machine
Is the thread caught in gear in top of machine causing it to bind. If you refilled bobbin did the gear switch back completely or you have lost an o ring in bobbin rewind.
Oct 16, 2014 | Brother LS-2125 Mechanical Sewing Machine
Hello, I have a Brother NX200-Innovis computerized sewing machine. It was sewing like a dream when all of a sudden it slowed down and beeped and flashed "E6" . The balance wheel has completely...
turn the sewing machine completely off
rethread the machine the top thread & bobbin, if possible use a different spool of thread for top & bobbin
then turn the sewing machine on again & see if you still get the same message, if the same message still displays,,then it needs to be serviced
Aug 10, 2011 | Brother NX-400
Needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
Jul 04, 2010 | Brother XL-3510 Mechanical Sewing Machine
Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Nov 15, 2009 | Brother PC8500D
Brother SE-270D balance wheel is very hard to turn manually
This is the first and foremost problems that I've found: The bobbin case is packed full of threads. The needle is crooked and must be replaced.
1. The bobbin case has a hook that turns to catch the top thread when the needle is down. The bobbin case assembly must be removed and cleaned totally. The bobbin case assembly is where the bobbin sits. The bobbin case has a black bar that sits on top of it. Listen the forward screw and slide the bar slightly. You will need to move the hand wheel to move the hook to the front-most position. When you have done this the bobbin case will come out easily. Clean it thoroughly and put one drop of oil on the track. This is a lower spot where the bobbin case sits on top of. Before you put the bobbin back in you need to check the tension. It is intended to be even with the top tension.
2. Replace needle and make sure it is in totally and is seated the right direction.
HOPE THIS HELPS
Apr 14, 2017 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
159 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
