Question about Troy Garden
Troy bilt clutch housing removal where is the set screw that holds it on
Remove clucth
Posted on Jul 03, 2009
  • vhewtty Jul 03, 2009
    remove clucth
Troy bilt tiller th-1002 Has no spark.
Couple of things. First thing I would do is take the wires off the back of the kill switch and the check for spark, I've seen a few bad switch's. If you still have no spark then the coil is next, getting to it can not be to easy you'll have to remove the shaft then the front of the engine housing next remove the clutch cover. What I do to remove these clutch cover is remove the spark plug and take a piece of 5/16 rope about 6 in. long and put about 3 in. of it down the spark plug hole pull the starter cord slowly till the piston come up to the rope and stops the engine from tuning. This way you can take a T-20 star driver and reach inside of the hole on the clutch cover and loosen the screw that holds the clutch cover on. (Leave the rope in the spark plug hole) Under the cover you'll find the clutch it's self, it's going to have the word off and a arrow stamped it. I take a brass drift and hammer to unscrew it but have used channel locks. Then remove the 4 screws holding the housing to the engine under all this you'll find the flywheel and coil. Some time you'll find the magnet's on the flywheel rusty and need to be cleaned with sand paper, or the pickups on the coil that reads the magnets dirty. But the only way to check and see if either of these helped you have to put everything back together and try it. So after doing all this work to get there its usually better to replace the coil with a known good one and then put it back together. Good Luck to ya.
Oct 13, 2014 | Troy Bilt 17 Inch 29 Cc Gas Powered...
HOW TO REPAIR PULLEY ON TROY BILT LAWN MOWER?
Replace the damaged pulley is the best answer. Don't know which pulley you are talking about as it has 2, 1 on the motor shaft and 1 on the transmission. Most have a set screw which hold them in place on the shaft, usually will be an allen type screw.
Jul 19, 2014 | Troy Bilt 5.5hp Self Propelled Mower
How do i remove the outer assembly spool on a troy built gas trimmer tb575ss
If you are talking about the side where the clutch is, there is a Torx screw inside the hollow part of the clutch housing. Using a #20 Torx bit, loosen screw. If this is the first time on this screw it will be tight and the drive shaft will turn with it. You will have to remove top of cylinder head and put something soft inside the cylinder to stop piston from moving up and down; usually a towel and something stiff like a screwdriver to hold it from moving.
After clutch housing is removed, the clutch itself is threaded and by holding the shaft with pliers you can unscrew the clutch.
Past this, just screws holding the plastic housing.
Aug 23, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do I replace the starter pull rope on TB70SS?
You must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Aug 15, 2010 | Troy Bilt Tb70ss Gas Trimmer
Cannot get the housing off so that I can change the pull cord on my troy bilt tb70ss grass trimmer
If you are holding the unit where the drive cable goes in, there is a screw in there. It is a #15 or 20 TORX screwdriver. Take out the screw and it will allow you to get to the starting spool. Good luck...Lee
May 29, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to remove clutch?
You have to pull the spark plug and fill the cylinder with some small rope then using a big pair of locking pliers you can loosen the clutch. There should be markings on the clutch as to the direction to unloosen.
May 13, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
I have a 4 cycle Troy Bilt and the head won't turn but the ...
Sometimes the only problem is that the screws holding the engine unit together has vibrated free and allowed the top shaft "square" to back away from it's proper position.
Jun 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Replacing pull cord on troy built mower model # 8654r 4hp
Remove the housing covering the clutch. The cord spool can then be accessed. Replace the cord. Be careful that you maintain the proper spool spring tension. Check operation before reassembling
Jan 10, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
268 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
