how do the pc faster withe the notepad? 1)open notepad and clear everything 2)type these "mystring=(80000000)" 3)save it to desktop :"ram.vbe" 4)go to desktop and double click it and there you go, you will notice your computer is alot faster and internet brows does take as long to load
you can but a daster cpu but you might need other equopment to keep the machine cool. Generally, if you buy a faster chip you will need better cooling.
A solid state drive will speed your machine up, SSDs are expensive but very quick, much faster than a magnetic hard disk. The best , most reliable bang for buck SSD is the SANDISK EXTREME PRO at the moment, these come with a 10 year warranty.
You can add faster ram . Lower CAS latency and faster chips really help.
SO
FASTER CPU
FASTER SSD
FASTER RAM
AND SOME IMPROVED COOLING
= FASTER PC BUT POORER OWNER!!
GOOD LUCK
STEP 1: Make Computer Faster by Upgrading RAM Step 2: Make Computer Faster by Removing Computer Viruses, malwares Step 3: Make Computer Faster by fixing registry errors (Use PC Fresher) Step 4: Make Computer Faster by Minimizing Startup Programs Go to Run. Type msconfig and press Enter. The General tab helps diagnose if the problems encountered are with drivers, services, or startup items by unchecking the appropriate boxes and restarting. The Startup tab allows you to individual disable or re-enable startup items.
Step 1: Make Computer Faster by Upgrading RAM Step 2: Make Computer Faster by Removing Computer Viruses, malwares Step 3: Make Computer Faster by fixing registry errors Step 4: Make Computer Faster by Minimizing Startup Programs
Also try to use computer optimization tool PCFresher to speed up windows.
To make your PC run any faster, there are several hardware requirement to consider i.e the motherboard, CPU, graphic card, ram, interface of the hard drives. The ram alone is not enough yo make your PC go any faster.
There is a misconception that by "adding ram your PC will run faster". The interaction of all the PC's components are all important to make any PCs run at a faster speed. (excluding overclocking tweaking)
You can make a computer move faster by removing some unecessary program that is installed on your computer to free up some memroy space and the best way to make much faster is upgrading the RAM or memory of the computer because the higher the RAM/memory the faster the computer works..
Without knowing the specs on your pc, best bet would be to add RAM and see if your internet provider has any faster connection speeds and see how much extra that would be. Other than that, not a whole lot you can do cheaply.
