Question about Jason Natural Cosmetics Jason Forma 72x36x22 Oval Combo Air-Whirlpool Tub - AC630
Refrigerator cooling but not real cold, freezer freezes ice but
Doesn't seem cold enough. Checked seal and cleaned coils didn't help. Seems to be running. Frost is on the inside of the freezer and there is no pooling of water at the bottom, the pooling has been happening for the past few month but not there isn't any water. Please help do i need a repair man or is there a part i can replace.
    President:
  • 2,976 Answers
***UNPLUG THE UNIT***
Take the cover off the back where the tubes go from the compressor into the freezer. If you can see into the freezer AT ALL, you have a mouse issue. Plug this hole with expanding foam. If you're getting room air into the freezer and your door seals aren't coming apart, it's usually from the rear. Make sure to melt all ice that formed in the bottom of the freezer before you plug it back in.
Posted on Jun 29, 2009
Freezer is icing up... when I dfrost it, it only gets to 15 degreees at the coldest, then freezes up again.
If the freezer is set at the lowest temperature the compressor will run continuously causing this. Also if humidity is high where you live and the seal on the freezer isn't sealing properly the excess moisture will cause it to ice up.
Mar 14, 2016 | Element Water Heaters
Whirlpool French door not making ice, but can get water. I had the water valve replaced and it still does not make ice help
Okay, here's a bunch of info in the order I would troubleshoot since the one year warranty expired.
1) The water filter might be clogged. Try just removing it to see if it makes ice. If it does change the water filter.
2) The water inlet valve might (still) be defective. The water inlet valve is an electro-mechanical valve. The coil can show good for continuity and still not let the water thru although you didn't say if it worked when he left. if recently replaced it should be under his warranty.
3) The water pressure in the house might be too low. The water inlet valve which supplies water to the ice maker is designed to work with a minimum of 20 psi of water pressure.
4) The door switch might be defective. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker and dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
5) It could be that the ice maker assembly itself is defective. The freezer temp should be between 0-5 degrees for the ice maker to cycle properly. There are several components in the control module of the ice maker that can fail and most are not sold separately. Also, ice makers have a relatively short lifespan and so it might not be worth fixing. If other, simpler parts like the water inlet valve or shut off arm have been ruled out, and the only thing left is the ice maker itself, replace it as a unit. Not as expensive as you may think...Under $100
6) The icemaker module at the front might also be defective. The module has a motor that cycles the ice ejector arms around to push the ice cubes out when the ice maker thermostat closes. It also has contacts in it for the mold heater and water inlet valve. The motor or contacts of the module can fail. Usually there are test points in the module that a service person can use to determine if there is a problem with it or one of the related ice maker components.
7) The icemaker mold thermostat might be defective. Inside the control module of the ice maker is a thermostat which monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature the ice maker starts a harvest cycle by ejecting the ice cubes and refilling with water. If the mold thermostat is defective the ice maker doesn't advance. The thermostat can be checked for continuity. Replace it as needed.The freezer temp should be between 0-5 degrees for optimum performance.
Sep 17, 2014 | Whirlpool Gold GI6FARXXY 25.5 cu. ft....
Paloma tankless water heater will ignite but shuts off after a minute or two on cold mornings. The first time it restarts it defaults to 120 degrees and the second time it defaults to 100. Seems to be...
No error code.
Incoming water is very cold.
Before calling service technician:
Catch up on maintenance.
Clean water filter.
Delime heat exchanger.
Check for crossover
Check water flow is high enough
Set temperature lower.
Install tempering tank.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 14, 2014 | Rheem Paloma Tankless Water Heaters...
Ice maker not working just changed the filter water works but ice maker not working
Check the plastic lever on the door. It usually moves closed when the door is shut to turn ice maker on. The lever can freeze and stop the ice maker.
Sep 23, 2013 | Whirlpool Gold GI6FARXXF 25.5 cu. ft....
Fridge not cooling! But the Fan and light is working! HELP!!
Sounds like you have caused a leak in the sealed system and the coolant is no longer inside it. You will need a professional to fix this.
Apr 13, 2009 | Jason Natural Cosmetics Jason Forma...
Whirlpool Refrigerator/Freezer not cooling
Unplug from wall and let unit subside 1 hour. then plug back in and check operation. Was unit tilted or moved prior??
Please rate. Thank you. jj505
Mar 28, 2009 | Jason Natural Cosmetics Jason Forma...
Furnace filter is black and sooty wall seem to be sooty
   By sealed unit you mean that the burner air comes from outside of the house?      You have checked the heat exchanger for cracks by removing the burners and looking with a mirror and flashlight, correct, or had a service tech so?
The furnace burners have enough air and are burning clean (blue) with just a tip of orange at the end? You bought the house new and the fireplace has never been used?  If it has been used to clean smoke for the house for whatwever reason I woudl start by havign the ducts cleaned.   Another possibility I have seen is insolation inside of ductwork breaking down.
Jan 28, 2009 | RTO Home Heating Products 5.5HH240...
Jason Natural Cosmetics Jason Forma 72x36x22 Oval Combo Air-Whirlpool Tub - AC630 Logo
174 people viewed this question
Top Jason Natural Cosmetics Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Jason Natural Cosmetics Water Heater Expert? Answer questions, earn points and help others
