Question about HP w1907 LCD Monitor
Hp w1907 Monitor problems
As soon I turn on the computer, the monitor wil say it's going to sleep mode, nothing else appears. The cables are attached in the right slots. It will ocassionally turn on every week or more. Any answers?
  • 788 Answers
Sorry to her about your Monitor problems.
In the feature it would help to know what kind of monitor, the brand and model.
If this is a option, turn the monitor on, when you get image on the screen, press the menu key and scroll around until you find factory setting.
Restore to factory setting may bring the unit back and out of sleep status.
Try it, it may work..!!!
John Ray
john@johnrraycomputer.com
Readers, please rate our information. Even if you disagree, it lets us know that you are responding and reading what we have taken the time to give you.
Thanks,
Posted on Jun 29, 2009
HP w1907 LCD Monitor goes to sleep by displaying a "monitor is going to sleep"error after turning on the computer and doesnt display anything. It works intermittently, in that, if the computer has been...
so if you test the monitor on a known good PC it does what?
fails, then its the monitor
works then its the failing PC
all old HP monitors pre 2010 many had a sleep timer
so push the menu key on the monitor
then look for sleep timer and turn it off,
the monitor defaults to that mode, so dont push reset monitor or bam back to sleep mode it goes. so turn it off again.
all this is in the manual, lost yours, wana read it first?
read page 4.7 see that? (osd +advanced +) power saver OFF
https://www.manualslib.com/manual/418165/Hp-W1907-19-Lcd-Monitor.html?page=25#manual
if that fails to fix it (tested on 2 PC ) the PC1 is bad.
that be a whole other WALL OF TEXt, ask.
Dec 10, 2017 | HP w1907 LCD Monitor
HP monitor going into sleep mode right after turning it on
If it goes in to sleep mode, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | HP w1907 LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
Monitor keeps going into sleep mode hpw1907 lcd windscreen monitor
right click on the desktop -- properties -- screen savers -- power -- turn off monitor then select 'never'.
your problem will be solved.
Apr 15, 2010 | HP w1907 LCD Monitor
Monitor going to sleep upon Bootup.
Open your cpu cabinet.
refix your RAM memory .
Pull cmos cell for 10 minutes so all settigns are defaults.
Also remove PCI cards from PCI slot .
Then check.
Let me know if you need more assistanse.
thanks.
Aug 31, 2009 | HP w1907 LCD Monitor
No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Jul 31, 2009 | HP w1907 LCD Monitor
hi
please try to take the computer in safe mode and then try to change the setting in display center and try to chage the value of power option and your computer monitor would be out from the sleep mode
Jul 07, 2009 | HP w1907 LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Disable sleep mode
For XP: Start>Control Panel>Power Options>Click the options you would like under the Power Schemes/Advanced and Hibernate. Vista may be a little different but it is still under Control Panel and Power
Don't forget to rate this solution with 4 diamonds.
Feb 22, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
536 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
