Question about Astro Pneumatic 7846 Harmonic Balancer Puller Set
How do i keep motor from rotating when removing balancer
Are the threads backwards
  • yadayada
    yadayada May 11, 2010
    u use a 1/2" drive air impact (with at least 400 foot lb's of torque) gun that's how.
    President:
  • 2,976 Answers
I remove the nut by putting the proper size socket on a breaker bar and stabilize it against the frame somewhere. Turn the key ***Just far enough to BUMP the engine*** This will loosen the balancer nut enough that you can remove it. When putting it back on, make sure all the plugs are installed. Tighten it the best you can. It will clinch when you start it up.
Posted on Jun 29, 2009
This is Rene and I cant find a puller with the right size bolts to fit my 98 park ave.. Its really a pain...
Posted on Feb 06, 2010
I replaced all balance springs. Still don't balance?
The washer is dancing across the room? Are the transit brackets removed? One on the motor, one across the top. Never known springs that needed replacing. With the top of the drum should move left and right a lot and backwards and forwards a little.
The washer must be level left to right and back to front. All four feet must be adjusted to sit evenly under the same pressure.
Bulky items or single large items will cause uneven balance. A normal load of socks, underwear, shirts, and a coupe of dish towels should keep balance as a test.
Oct 24, 2015 | Washing Machines
How to replace seal on a
remove the motor from the wet end of the pump remove the cover on the impeller then remove the impeller screw it it normally backwards thread then spin off the impeller this has a regular thread split the motor from the backing plate then remove the seals and replace with new ones then reverse process
Jul 13, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Harmonic balancer removal
Hello:
I have removed several of the harmonic balancer bolts, and it is difficult to hold the harmonic balancer from spinning when you remove the bolt. The bolt is normal thread, and removal is counterclockwise. There is a Honda holding tool you can get, or possibly borrow from a autoparts store. I always use either an impact wrench or a long breaker bar, and hold the harmonic balancer from rotating with a chain style wrench. I use an old belt to keep from damaging the damper pulley.
Apr 18, 2014 | 1998 Honda Civic
Bosch GSB 18 VE 2 Drill
https://www.youtube.com/watch?v=RxZux85j3eE
Sep 29, 2017 | Drills
Pentair 011523 pump shaft seal is leaking. How do you remove the impeller and motor?
Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
Sep 04, 2013 | Pentair 011523 WhisperFlo High Performance...
Remove impeller pool pump
remove band clamp remove motor undo cover over impeller hold back of motor shaft unscrew holddown screw backwards thread then un screw impeller regular threads
Aug 31, 2013 | Sta Rite Pool & Spa
How to separate pump from motor
take screws off around housing that separates motor from wet end remove diffuser then remove screw from impeller backwards thread and hold back shaft of motor after removing still hold shaft and turn impeller off regular threads make sure to replace seals
Apr 16, 2013 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Installed plastic impeller backwards. How can I stop the motor from turning to get the nut off?
With power off, block the motor shaft to prevent rotation while you remove the nut.
Jan 31, 2011 | Koblenz U110 Upright Vacuum
Bottom pully. 1990 mit mirage wagon . i have tried with a air gun but it still won't budge.
are you turning it the right way, most harmonic balancer bolts are backwards thread, if you have tried both directions put a socket and breaker bar on the bolt then rest the breaker bar (still attatched to the bolt) against the chassis and then turn the car over with ign, the bolt always tightens against the rotation of the engine so the turning of the starter motor will undoo the bolt for you. hope this has been helpfull.
May 16, 2009 | 1990 Mitsubishi Mirage Hatchback
Harmonic Balancer
need a harmonic balancer puller.. Can be rented at some auto parts stores. Some will sell them.
It threads into the hub of the balancer and has a bolt in the center that is rotated to exert pressure on the crankshaft.
Each rotation of the bolt will create more force and move the balancer a little at a time until it is clear of the end of the crankshaft.
Feb 15, 2009 | Astro Pneumatic 7846 Harmonic Balancer...
Astro Pneumatic 7846 Harmonic Balancer Puller Set Logo
213 people viewed this question
Top Astro Pneumatic Air Tools & Compressors Experts
Trippy Tripp
Tom Chichester
Are you an Astro Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
