Question about Coleman Mach III Air Conditioner
Ac fedders portable
I turn on my ac it runs for about 4 minuts and makes a noise and it turns into heat and my motor to pull the heat out doesn't run
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Posted on Jun 29, 2009
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Fedders D Chassis A6D24E7A Air Conditioner
My fedders a/c will turn on fine but after some minutes the fan will stop but the compresor will still work. i will haveto turn it off and turn it on again after 10 minutes and it will work fine again. but...
You need to replace you fan motor. It is going bad and the amount of amps to keep it going is causing it to over heat. The next time you try it and the motor kicks off see if the motor frame is hot. Be careful I have seen the hot enough to cook eggs. These motors can run between 68 dollars and 160 dollars. The age of the unit and your ability to replace the motor dictates a repair or a replacement. If you ck on the price of the motor and want to do it your self I will be happy to walk you thru it. good luck
Aug 26, 2010 | Fedders A6X05F2D Air Conditioner
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
Purchased a fedders a/c 18000 unit still under warranty. called the 800# they said company had filed bankruptcy and were not responsible for repairs. 350$ mistake. Fan runs too slow for unit to kick in....
Check the capacitor for the fan motor. You can do that with a multimeter with the capacitor test function or if the capacitor looks swollen then it is probably bad. Also, make sure the fan rotates freely by hand. Let me know if you need more help.
Jun 08, 2010 | Fedders 12,000/10,200 BTU Heat/Cool Room...
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan...
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
May 12, 2010 | Fedders A6P09D2B Portable Dual Hose Room...
Fan is making clunking sound like it is hitting something.
Yes, it certainly can be, especially in high humidity. Run AC just about 1/4 way from max and crack the windows. The ac will work better and ice up less.
Jul 29, 2009 | Fedders U Chassis A7U12W2A Air Conditioner
Coleman Mach III Air Conditioner Logo
98 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
