HP DeskJet 5150 InkJet Printer Logo
A
Anonymous Posted on Jul 21, 2014
How do I get an HP Jetdirect Print Server if it is not on my computer?
MY computer is new and it may not have an HP Jetdirect Print Server such as HP 175x, HP 310x, or HP 380x.
David Payne
Level 3:
Top Expert:
  • HP Master 14,162 Answers
  • Posted on Feb 18, 2016
David Payne
HP Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998272
Points
455836
1 Related Answer
Anonymous
  • 1187 Answers
  • Posted on Sep 08, 2009
SOURCE: I have a hp PSC 1610 all in one printer, connected
Two ways to do this:
Since this is a USB printer and not a network printer you have to create a "share":
1. On the main computer that has the printer attached, go to the printer properties (START, PRINTERS AND FAXES, Right-click on the printer icon and select "sharing"
2. Select the Sharing" tab and select "Share this printer" radial.
3. Enter a short name for the printer in the "Share Name" box, such as: HP1610
4. Save that configuration and remember the "Name" you gave the share.
At each computer on your network:
1. Go to the printer setup sceeen (see #1 above)... and "ADD A PRINTER"
2. Select "Network" printer (not local printer)
3. Select "search for printers and the HP1610 will appear on the list.
4. Select it and follow the instructions from there...
Hope this helps!
How do I set up an HP JetDirect 170X Print Server with Windows 8.1 Operating System?
Connect the printer to the print server. Push the test button on the test button on the print server. Two pages will print. One of the pages will contain the IP address for the print server. Connect the print server to the router. Now you need to go to the Control Panel and select "Devices and Printers". Select "Add a Printer". When it searches for a printer, select "The printer I want isn't listed". Next, select "Add a printer using TCP/IP address or hostname" and click "Next". Now, enter the IP address from the test print and click next. That will do it.
2answers
Why is my jetdirect en3700 not picking up laserjet 1020?
Laserjet 1020 is a Host-based (WIN) printer. It must be connected to a Windows PC directly.
Network can't ping jetdirect 615n card
why not ask at HP and not here, why ask on non HP forum.?
the HP enterpise forum covers this.
ask here first., they will direct you to OLD hardware help.
https://h30434.www3.hp.com/
here im searching there, see all those posts there.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=JetDirect+615N
3helpful
3answers
How to change the ip address of a hp jetdirect 170X
The manual is located here, and it recommends the following procedure, which starts on page 18.
Connect the Jetdirect box to the printer and the network and power on.
Press the Test button on the back of the Jetdirect box to print a configuration page.
The configuration page should show the IP address of the Jetdirect box.
If this is an IP address in the normal range of your network, ie the first three numbers of the Jetdirect box's IP address and your computer's IP address is the same (such as 192.168.0.) then simply type the IP address into your computers internet browser and you can reach the configuration page. The steps on page 58 detail the user interface for the web login.
If the Jetdirect box does not get an IP address withing 2 minutes of it booting up, it assigns itself an IP address of 192.0.0.192, and you can connect to it over the network if you change your own network settings to 192.0.0. and a number from 1-254 (but not 192).
1helpful
I'm pretty good at most computer stuff, but I'm stumped. I'm trying to connect an HPlaserjet5/5m to an HP 170X Print Server on a 16 port dlink switch. I cannot get the hp setup.exe to work off the...
I am not sure if you need the setup.exe file to configure the JetDirect 170x.If you take a look the manual for the JetDirect 170x (http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00758101/c00758101.pdf) it mentions that this is a "Test" button on the back of the print server. If you press that button when the printer is connect, then it should print out a configuration page. The configuration page will have an IP address that you can browse to with Internet Explorer to configure the JetDirect.
All printers with HP hJetDirect 615n card not printing
Known failure with the jetdirect 615s, the more reliable cards are the 610 or the 620. According to HP tech support stay away from the 615.
All printers with HP JetDirect 615n will not print
Is the 615n an internal print server not one in the EIO slot. From memory if so it has a really high failure rate. Try getting JetDirect cards for EIO slots and seeing if they work.
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
Laserjet 2300d hasstopped printing to a HP Jetdirect 170x suddenly
parallel cable connected?
omg this? "old centronix")
IEEE 1284 standard
parallel-zw1hxsxncju1x1hxxv3nm1gz-1-0.jpg RTM yet? check the manual carefully
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=27317&docLocale=en_US&docId=emr_na-bpj06151
The HP JetDirect 300X provides connectivity to 10Base-T and
100Base-TX networks. The HP JetDirect 170X provides
connectivity to 10Base-T ne
tworks. The HP JetDirect EX Plus
provides connectivity to 10Base-T and 10Base2 networks.
HP JetDirect 170X (J3258B):
Bidirectional parallel port (IEEE 1284).
Network port (Ethernet): RJ-45 (10Base-T).
Test button (sends print server configuration page).??????????
2 LEDs on front indicate LAN activity/status
k24674
Grand Canyon Tech
Grand Canyon Tech
