Question about Weber Genesis Silver B Grill
My weber genesis platinum gas grill won't get hotter than 300 deg
I checked to make sure there were no obstructions and that the natural gas is properly flowing. After taking it apart and reassembling there was no change. could it be the thermostat?
    President:
  • 2,976 Answers
Are you using natural gas or LP gas. If LP, replace the regulator filter. If clogging, you won't get the full amount of gas.
Posted on Jun 29, 2009
Just bought a Weber Genesis II LX Model S-340 Natural Gas Grill. The plumber installed a 54' line, 1" in diameter. The grill will only heat up,to 400 degrees. What could be wrong?.
If he really installed a 54 foot line instead of a 54 inch line, the line is way to lone. The gas pressure isn't high enough to supply enough gas to the grill to get any hotter.
Oct 19, 2017 | Weber Grilling
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
I just want to know if I can use Charbroil's natural gas conversion kit to convert my Weber Genesis Silver grill.
NO. Weber grills have never been approved for gas conversions.That's why they made/make Natural Gas models & Propane models. Doing so, puts all the liability in your lap, if some thing should go wrong.If you have any doubts, check your Owner's Manual under "Warnings."
Hope this helped to answer your question. Thanks for choosing FixYa.
Aug 27, 2011 | Weber Genesis Silver B Grill
Bought a brand weber sprit grill from home depot. Used 4 times. Won't go above 350
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ';';
Aug 11, 2011 | Weber Genesis Silver B Grill
I have a weber genesis grill. It did not heat up above 425 degrees at first and now it does not go above 300. This is with the searer on as well. Does this make sense to you? It is hooked up to a...
Was your grill originally set up for Natural Gas or did to convert it from Propane to Natural Gas? If so, where did you get the conversion kit? It may have been missing some vital parts.
If it was not a conversion, did the grill come with a natural gas regulator already installed?
Please advise... Thanks
Jul 18, 2011 | Weber Genesis Silver B Grill
My weber grill won't heat up beyond 200 degrees - why>
heatman101 ,,./,./
May 28, 2011 | Weber Genesis Silver B Grill
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
Kit for converting weber genesis silver c to natural gas
Some grills do not have conversion kits, if your grill is labeled as dual fuel you can contact weber and get a kit for it.
Dec 31, 2009 | Weber Genesis Silver C Grill
Weber Genesis Silver B Grill Logo
808 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
