Question about Sony KDF-E42A10 42 in. LCD Television
KF-WE42 Indicator flashes red.
As per the manual there is self-diagnosis function forthat model TV and the number of times the indicator flashes red indicates the possible causes. Suggestion is to inform the Sony service center about the number of times the indicator flashed.
I counted six times between 3 sec intervals but still have no idea/solution how to power up the TV.
    President:
  • 1,077 Answers
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
RED STAND/BY LIGHT WILL COME ON BLINK SEVERAL TIMES, HEAR A CLICK SOUND A FEW TIMES BUT TV WILL NOT COME ON,
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 09, 2011 | Sony Televison & Video
Sony bravia KDF-50E2010 RED LIGHT FLASHES 4 TIMES THEN 3
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
continue f
Jul 08, 2011 | Televison & Video
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
My Sony Grand Wega picture went out & red stand by light flashes 3 times then pause & flashes 3 times again. What is wrong???
the reason the tv flashes its l.e.d is to tell you there is a major fault in the main circuit board (pcb) and needs to be fixed its not a fuse it not a reset problem its a dynamic fault that could be from a bad resistor to a downed capacitor if you have knowledge of these components then check them using a multimeter find the faulty parts and replace accordingly. but if you have no idea then it will need to go into the repair shop. a lot of our customers ask us if the unit (tv) etc after being fixed will be any good or should they buy a new one. a good tech will fix the unit and in most cases it will be tweeked and work better but always get a quote up front and hold them to it within $50.00
best of luck to you
if you need further advice please feel free to email us at sonicboomelectronics@hotmail.com
merry christmas
please take the time to rank this advice if it helped you.
Dec 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
A/C won't work 03 Acura RSX
General Troubleshooting Information
How to Retrieve a DTC
The Climate Control Unit has a self-diagnosis function. To run the self-diagnosis function, do the following:
1. Turn the ignition switch OFF.
2. Tu rn the fan switch OFF, the temperature control dial to MaxCool (60.F or 18.C), and the mode control dial to Vent.
3, Turn the ignition switch ON (ll),then press and hold the recirculation control switch. Within lO seconds while holding the switch down, press the rear window defogger switch five times. The recirculation indicator blinks two times and the A/C indicator comes on, then the self-diagnosis will begin. About 15 seconds later, the self diagnosis will finish and the Ay'C indicator goes off. lf there is any problem in the system after finished self diagnosis, the recirculation indicator will blink the Diagnostic Trouble Code (DTC) 1 through 13. When problems in the evaporator temperature sensor circuit are detected (codes 14 and t5), the A/C indicator will blink the DTC. lf no DTCs are found. the indicator will not blink.
d35f123.jpg 695f305.jpg5d11822.jpg Resetting the Self-diagnosis Function
Turn the ignition switch OFF to cancel the self-diagnosis function. After completing repair work, run the self-diagnosis function again to make sure that there are no other malfunctions.
Jan 13, 2009 | 2006 Acura RSX
Got a sony grand wega kf-42sx300u tv. the standby indicator on the tv flashes
Im afraid my friend the lamp needs replacing (model: XL-2100E), if you have a hunt on google you will be hit with the pain of the cost... like me :(
Aug 11, 2008 | Televison & Video
Sony Tv repair
it is not possible for you to get it corrected as it requires tech knowledge. please call tech person at your place to do needful. it is not a serious problem.
Sep 22, 2007 | Televison & Video
Sony KDF-E42A10 42 in. LCD Television Logo
309 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
