Question about Kenmore Elite 45986 Front Load Washer
The power button is on, but will not turn on. the other lights are not on either. when I push the button it doesn't respond, it won't turn off either.
  • mommy2honeys Jun 29, 2009
    I flipped the circuit, nothing is working still.
    Ok it worked!! Thanks so much! Now I can get back to the mountain of laundry.
Unplug for a minute and plug back in.....or turn off the circuit breaker..and turn it back on...(I did this because I couldn't reach the plug)
Posted on Jun 29, 2009
  • Florida42 Jun 29, 2009
    sorry it worked for me...keep the circuit off for 5 minutes turn on curcuit and push the cancel button in for a minute
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
Infocus screenplay 5700 I've had this product for
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
Jan 05, 2013 | Office Equipment & Supplies
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
The home screen is frozen it doesn't even respond to me trying to turn it off.
Hold the power button for a few seconds. If it still won't turn off, remove the batteries.
Jul 30, 2011 | PANDIGITAL Novel 7
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My Sony vaio pcg 3c2l has locked up. The keyboard stopped responding and now the screen is black, but the power light is still on. The power button doesn't respond when I push it. What should I do?
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 05, 2011 | Sony Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
