Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
Red door spring GE monogram fridge side door
The red door spring snapped on my GE Monogram side by side. I fixed it temporarily by bending the broken end of the spring with needle nose pliers. Not sure how long the fix will work.
  • Carmen Sandiego
    Carmen Sandiego Feb 27, 2014
    I hate when my fridge door breaks, or any door for that matter. That's why rather then try and fix the problem myself, I just call in the professionals. Last week my garage door broke thanks to my kids so I decided to check out http://www.omgdoor.com/commercial_doors and they were able to come over and fix the problem in no time.
Spring closure part # WR2X8916 from Sears Parts.
Posted on Aug 19, 2009
GE Monogram refrigerator feeezing even when thermostat is set at 45
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 07, 2010 | GE Monogram Side by Side Refrigerator
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Door on Monogram ZIR36N won't pull closed and stay shut
The spring is actually a door closure , are the wheels that the bar closure mechanism goes through and attaches to the spring moving freely? It is entirely possible that a bin in the fridge is keeping the door open.
Nov 14, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
906 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
