Question about Samsung HP-T4254 42 in. Plasma Television
Its automaticly turn on n off non stop n the tv never turn on
    President:
  • 1,077 Answers
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
I have a Smith Cornona Electra XT. It still turns on, but when I do turn it on, the carriage automatically goes back and forth non-stop and it's like you arre holding the return button down conti
Find the problem, some linkage is sticking and you have to trace it through. Spray with WD40, then when working spray with other light oil, cause WD40 does not stay. Most likely the carriage return release . Take bottom off and watch what it hits on the left side, Also the tab button locked down will do this.
Jun 16, 2017 | Smith Corona Electra Xt Portable...
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Sep 21, 2011 | RCA F32689 32" TV
My television problem is the channel is keep on changing automatically non stop. How can i go to channel tunning? This problem was happened just 11 months when i bought it and i send it to the Sharp...
Hello, there are three options for such failure, the first and simplest is to try to get the remote control out of the room while the TV is off when it is in stand bye. A second possibility is the micro switches in front of the TV, you can verify that they cause failure by disconnecting the cable that connects them to the main board. If the problem stops, you will need to replace all the front switches. And now the last option, however the more expensive one, that there is a malfunction of the micro-processor circuit, from which comes the command to turn on the TV. let me know if that was helpful! Please come back to me, if you have any questions or if you need further guidance
Mar 06, 2011 | Sharp Televison & Video
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Jun 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Tv turns off on its own. power light now blinking red, tv not on
Unplug,replug,push the popwer buton couples time,see if stable green LED light,should get tv pic& suond back, not replaced the backlight video board it some how die.
Nov 26, 2009 | Televison & Video
AOC Plasma TV turns on by itself and changes channels non stop.
I have an AOC 32" LCD HDTV and it turns on by itself as well. Tuning is done via my cable box, so the tv is set on HDMI and I don't have the channel changing issue. I as well am trying to figure it out. The only thing I could suggest is perhaps the remote batteries are low and triggering on it's own. Try changing the batteries, or ensure that the remove it in a drawer or other room so that triggering the unit is impossible. Hope that helps.
Jun 17, 2009 | AOC A42HD84 42 in. Plasma HDTV
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Samsung HP-T4254 42 in. Plasma Television Logo
151 people viewed this question
Henry  Thomas
Henry Thomas
