Telescopes
Problem for Telescopes
Generic problem for all Telescopes
HI! I own a Meade ETX-90
By maraterese on Jun 29, 2009
HI! I own a Meade ETX-90 telescope. The right ascension drive does not engage. Do you have any troubleshooting suggestions on how I might go about fixing it? Best, Mara
Comments:
Jul 01, 2009
- Hi there! thankss so much for following up! yes - you are exactly right about the sounds it makes - I think this is precisely the problem -- I am however looking for ways to avoid sending the telescope back to Meade, if at all possible. Is there any easier fix for this? I took it to Company Seven in Maryland -- a highly reputable shop. They won't touch it. Any suggestions are welcome. Mara
Clarification Request
Posted by erichidle on Jul 01, 2009
The RA drive is the axis that rotates the base of the mount, is that right? It is not the axis that rotates the OTA in the fork? There are often issues with the low-end Meade mounts, both Alt-Az and RA-Dec. They use cheap nylon plastic gears and jackscrews that can get brittle and crack. It is also common for the jack screw to become disconnected from the motor spindle, preventing it from turning the axis gear. I have a DS series mount that has the same kind of problem where the computer tried to rotate the OTA beyond the limit stop in the Altitude axis, and it actually backed the jack screw into the motor, crushing the jack screw. Does your mount make any popping or cracking sounds when you try to slew the RA axis?
Best Solution
posted on Jul 11, 2009
Helpful)
Joe L
Rank: Guru  Binoculars & Telescopes  Expert
Rating: 89%, 247 votes
Go to the Mighty ETX web site and look around for all the repair and disassemble topics.
http://www.weasner.com/etx/menu.html
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Telescopes
Questions and Unsolved Problems for Telescopes
Answer
can you tell me if you would recommend the vivitar 60*/120* refractor telescope to look at the... (More)
Answer
Trying to decide which telescope to buy for a beginner, any suggestions?
Answer
have infinity telescope, model 60eq-d, no manual, not working, need manual and/or local... (More)
Answer
connect pc to tv using vga. What button do I push to activate connection
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Telescopes Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
