SOURCE: hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
SOURCE: I purchased a ceiling fan
That is kinda confusing, but it sounds like the blue wire for the light kit should also be connected together with the red supply wire for the fan motor from the ceiling wires, and not the capped black wire. That is if the two wires to the fan motor are the white and red wires from the ceiling. Normally the white wire is a neutral wire and the black is the field wire and they both are alternating current "hot" wires, and the green wires are grounded to earth ground only.
Let me know if I understood that right about the wires from the ceiling, and let me know if you require any further assistance.
See if this diagram is correct
SOURCE: I have a red, blue,
go to the other end of the wires, where they connect at the furnace -- properly identify where they are hooked to and then hook them up accordingly onto the thermostat. If you removed the other thermostat, I trust you wrote down or know where the wires hooked into the old unit... you may be able to proceed from there with the manual. You could also call Hunter's customer service on Monday, if you can get by till then.
Best regards
Ck
