Question about Kenmore Dryers
How hard is it to replace a hinge on a kenmore dryer? My 20 year old machine has a broken hinge on the right side of the door. Is this a giant undertaking to fix? I can get the part ofr $16!
  • colejk Jun 30, 2009
    Great - so, how does the front panel come off?
  • 999 Answers
The hinge is not difficult at all. take the door off and remove the front panel to make it easier.
Eric
Posted on Jun 30, 2009
  • Eric Duda
    Eric Duda Jun 30, 2009
    The top flips up and there are 2 screws in the upper corners. Two screws where the lint screen goes on and clips in front that will release with a putty blade.
    eric
How to tighten kenmore dryer door. model 417.91122310
kenmore doesn't make anything the only way to tell who made the dryer for kenmore is by the first three numbers on the model number,417. is frigidaire and the hinges on their doors aren't to good,the door always sags but you have to replace the door hinge part 137105100 you can try to see if the screws are loose but most likely it will be the hinge,when you put the new hinge on you have to close the door slowly and don't slam it closed or you'll break that one too.go here to see part
https://www.repairclinic.com/PartDetail/Door-Hinge/137105100/1614940
go here to see how to change out door hinge and heads up this guy has a lovely voice
https://www.youtube.com/watch?v=Zx7JTmty61A
or if you meant the door isn't staying closed you have to change out the door catch part 131658800 go here to see
https://www.repairclinic.com/PartDetail/Door-Catch/131658800/835
look at the area where the door closes in,the door catch might be cracked or broken,it's hard to get the part out so just push it into the door and leave it in there,now get the new catch,make sure the slot in the middle is going up and down the same way the old part was and push it into the hole and you're done,and stop slamming the door lol hope this helps you out if you want to see all parts on your dryer go here and put your model number in
https://www.searspartsdirect.com/model-number/41791122310/0582/0151200.html?searchType=modelSearch&q=417.91122310&searchTerm=417.91122310
Feb 02, 2018 | Kenmore Dryers
Kenmore 110.62622101 dryer door hinge is broke
It will be as you are facing the unit.
Sep 08, 2014 | Kenmore Dryers
Switching a kenmore dryer door from right to left. I have taken off the door.. but it looks like I need to remove the plastic covering on the door to remove the hinge and install on the other side. There...
In General the deconstruction of the door is not needed. With a great deal of Kenmore dryers you can simply turn the door 180 degrees and reinstall it.
Aug 24, 2011 | Kenmore 85871 Electric Dryer
My drivers side door drops every time I open my door. Is it because of the door hinge or do I need to replace the door pins?
the hinge pins rides on brass bushings. if the door does not latch replace the pin and bushings with oversized ones available at Chevrolet parts department
you will need a sring compressor which is available at Auto Zone
Feb 20, 2010 | 1990 Chevrolet S-10 Blazer
I have a Kenmore dryer from 1979 and when I open the door it just falls down. Is there anything I can do to fix this?
Check the door springs. One or both may be broken. Remove bottom panel and look to the right or left sides for the springs. If broken, just replace the same. One end of the spring hooks into the door hinge assembly and the other end hooks into the base of the frame. You should be able to see a hole in the frame to hook the spring as you will also see a hole in the hinge assembly. Easy fix. Just have to know where to look.
Jan 16, 2010 | Kenmore Dryers
Washing machine doors
Electrolux has a reversible door for both front load washer and dryer. Just found that out at HHGregg because we need to put our washer to the right of the dryer, and none of the other makes will allow the washer door swing to be switched.
Apr 11, 2008 | Kenmore Elite 45986 Front Load Washer
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
77 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
