Question about Maytag Washing Machines
When we go to use the hot water , the machine will not fill. it makes a buzzing noise.when we use cold, no problem..both hot and cold water is turned on. it was working fine.
    President:
  • 2,976 Answers
Take off the hot fill hose and check the screens in the washer and the hose. Drain & flush your water heater at least once per year to prevent dirt from getting into your water systems. Shut off the water supply. Shut of the heat supply (Gas or electric). Attach a hose to the drain valve and put it into a floor drain. Open the drain. When the water stops flowing, open the water in valve for about 5 seconds. Catch some of this in a jar and you will see what you've been using. Repeat the 5 second fill a few times, until it runs out clear. Shut everything, remove the hose & turn the heat supply back on.
Posted on Jun 29, 2009
    President:
  • 1,185 Answers
Filter blocked on the hot fill valve inlet
Solenoid not lifting within the valve
Clean the first
Replace the second
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
Our Roper Top Loading Washing Machine won't fill with cold water and the machine makes a electrical buzzing noise when you turn it on set to Cold/Cold.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
Jan 20, 2016 | Roper Washing Machines
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
Whirlpool washing machine does not rinse just a buzzing noise
The buzzing is the water valve, the timer is sending power to the valve but no water is coming out. I would set to wash and as it is filling up change the water to cold then to hot while it's filling. I bet either cold or hot will buzz (usually hot). Once you determine which (clod or hot) shut that supply off, take that water line off the washer, put the end in the washer and turn the supply back on. If water comes out then look inside the valve where the hose connects, it could be clogged. If you have water going to the valve and you don't see a clog then the problem is inside the valve...replace valve.
Oct 21, 2014 | Whirlpool Washing Machines
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
To fill tub with hot it makes humming noise only, turn to cold to fill tub cold water only
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Mar 31, 2011 | Washing Machines
Machine stopped in the spin cycle, now only makes noise.
Be sure BOTH fill hoses are hooked up and TURNED ON. What happens is (commonly) hot and cold hoses are installed reversed, and no one really notices.....Then Dad gets a big hot water bill and turns off the HOT water (actually hooked up to the cold input on the machine), so when the machine gets to the rinse cycle, no water comes in, and it waits patiently (forever) for water which never comes. The buzzing is the water valve. This is the most common problem.
Dec 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
No hot water filling washer
Check to see if there is a filter located in the valve, remove and clean.
If still no hot water then disconnect hose and make sure you have actually got water at valve, if you have and it still does not come in, and you can hear a buzzing noise, then I would say that it is sticking and you have a faulty inlet valve, only solution is to replace said valve.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Washing Machines
Washing Machines Logo
88 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
