Question about Kenmore 22422 Top Load Washer
Water will not drain
Kenmore 70 series top loader washer. water will not drain out
  • 15,935 Answers
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Apr 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore70 series washer 110.26752502 leaks water while filling
If you have a leak on a TOP LOADER, the most common cause is a worn drain pump, leaking drain hoses or the hose to the air dome has come loose. You will need to remove the exterior case of the washer to be sure. DO NOT lay the washer on its back. The gearcase contains oil and it may leak through the breather hole.
The following link explains how to inspect a TOP LOADER for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the drain pump is leaking, it is not serviceable and must be replaced, the following link explains how to replace one:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) may be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
Read through the instructions provided and let me know if you need further assistance. The choice is yours if you wish to pursue this repair on your own. In my opinion, you don't need a "certified repairman" to find the source of a leak in most cases. Many of these repairs are simple with a little guidance. I hope this help you.
Feb 11, 2010 | Kenmore 22422 Top Load Washer
Kenmore 70 series top loadwasher does not completely drain water
the smell is raly bad because it doesnt drain all the water out , so it sits there. if all else with the machine works well, this means the water level sensor needs replacing
Jul 19, 2009 | Washing Machines
How do I remove the pump from a kenmore 70 washer?
The Kenmore 70 series is a top loading washing machine. Different from the picture you have this listed under. If this is a Kenmore top loader, the following link explains how to replace the water pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this is a front loading Kenmore, the next link applies:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series top loader - wouldn't drain & spin
The lid switch is the only thing affecting this part of the cycle. The new switch comes with the new plug (under console ) and the harness that goes to the switch. The console will flip up and the cabinet will pull forward after removing 2 brass looking clips. After that it's right there under the right side of the upper cabinet.
Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
Water is coming out of the bottom of the washing machine
Tip the machine back and remove the 2 clips holding on the drain pump. Remove the hoses. Then turn the pump over to where the motor shaft enters it. There will be signs of water leaking out of the pump. Your local parts store will have the pump instock.
Nov 22, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Top loader won't spin
it is a problem with the lid switch. check for continuity. if the lid is close , it should have continuity, if you open the lid, it should be open also.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 23822 Top Load Washer
Kenmore 22422 Top Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
