Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How do I remove washer lid whirlpool brand
Remove a whirlpool lid
    President:
  • 3,113 Answers
Unscrew the two screws on each side of the lid by the hinge.
Posted on Jul 01, 2009
Estate by whirlpool model SM8280867. Filled, then stopped. What's wrong?
Charla, By what you have stated, it sounds like a lid switch failure. I recommend checking the screws for the lid hinge first.The lid has to be closed for the motor to run in the washer. If the lid switch is faulty, it will act as if the lid is open. A quick check you can do is to run a cycle with the lid switch jumped. If the washer operates, the lid switch needs to be replaced.
To jump the lid switch you need to unplug the washer and open the console.Once you have the console open, locate the connector for the lid switch. Place an insulated jumper between the gray and white wires. Not the green it is a ground and will cause a short. After inserting the jumper make sure it will not touch anything metal, plug the washer in. Then start the washer in a cycle, and let it go. If the washer completes the cycle, you need to replace the lid switch. Remove the jumper and order the part. The jumper is only of the test do not continue to operate after test.
Whirlpool Appliance Parts
Whirlpool Appliance Parts Whirlpool Appliance Parts from Easy Appliance...
http://www.repairclinic.com/Shop-For-Parts/a11b5/Whirlpool-Washing-Machine-Parts
Mar 05, 2016 | Whirlpool Washing Machines
Brand new Whirlpool WTW4800XQ out of box . Set up plugged in , loaded load pushed start lid locked hummed lid lock started flashing. waited till lid lock went off Still nothing
Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
Call your dealer if the set hums even after the initial checks were done.
Aug 04, 2011 | Whirlpool WTW4800XQ Washer
HOW DO I BYPASS KENMORE SERIES 80 LID SWITCH ON THE WASHER. IT WILL NOT SPIN , BSD LID SWITCH.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jun 07, 2010 | Kenmore 22942 Top Load Washer
Replace lid switch on whirlpool washer # LSB6300PW2
The following link explains step-by-step how to access the lid switch on your washer:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
The lid switch on your washer is located by the left lid hinge under the washer casing. Simply remove the mounting screws, any ground wire and slide off the actuator rod of the lid hinge.
NOTE: In some cases, what appears to be a bad lid switch is a simple matter of adjusting the actuator rod by bending it slightly to make better contact.
If you have questions about this repair, please let me know. I hope this helps you.
Nov 27, 2009 | Whirlpool LSR5132J Top Load Washer
Washer lid switch replacement
there is a screw right on the edge of where the clothes go in the washer on the right side,remove the top cover ans unplug lid switch harness, remove lid switch and then replace lid switch and reverse the procedure
Oct 28, 2009 | Sport & Outdoor - Others
My whirlpool washer won't spin dry
There is a failsafe mechanism that will prevent the washer from spinning while the lid is open. It is possible that either the post has broken or the switch has failed, making the washer 'think' that the lid is open. The filling and wash cycles will operate normally even if the lid is open.
Aug 21, 2009 | Whirlpool Washing Machines
Washer does not drain and spin
If this a whirlpool brand washer, check your lid switch. When they start going bad, they can be intermitent. While the washer is in the spin cycle, if there is no motor noise, push down on the lid above the lid switch and see if it starts.
This is the most common issue.
I hope this helps
Vic
Jun 20, 2009 | Washing Machines
Need to replace lid switch
what brand machine? whirlpool take off the cabinet and the switch is on the rhs under the lip
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replacing lid switch for whirlpool washer LSR5132JQ0
U WILL NEED TWO TOOLS TO DO THIS JOB.A PHILLIPS AND A FLAT SCREW DRIVER.YOU NEED TO OPEN THE LID AND REMOVE THE TWO SCREWS THAT ARE LOCATED ON EITHER SIDE OF THE LID SWITCH OPENING.YOU THEN NEED TO LOCATE THE TWO SCREWS THAT HOLD THE CONTROL PANEL DOWN.ON THE SOUTH AFRICAN VERSIONS OF THE WHIRLPOOL TOPLOADER THEY ARE IN THE FRONT OF THE CONTROL PANEL WERE ITS VISIBLE ENOUGH TO YOU.REMOVE THEM AND LIFT THE CONTROL PANEL UP AND BACK.YOU WILL NOTICE TO CLIPS ON EITHER END OF THE TOP REMOVE THEM WITH A FLAT SCREW DRIVER ALSO REMOVE THE WIRE LUG ON THE RIGHT SIDE.YOU WILL THEN NEED TO REMOVE THE CABINET BY OPENING THE LID AND PULLING IT TOWARDS YOU IN A SLIGHT UPWARD POSITION.NOW THE DOOR SWITCH IS LOCATED ON THE CABNIT IT SHOULD BE SMOOTH SAILING THEREAFTER.TO PUT THE MACHINE BACK ITS THE SAME WAY YOU REMOVED IT.AS FAR AS A PICTURE THERE IS NOT MUCH AVAILABLE.GOODLUCK.MOHAMED
Oct 07, 2007 | Whirlpool LSR5132J Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
170 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
