I keep getting ink system failure or Error Oxc18a0001 even after replaceing ink cartriages. I've tried everything I can find on line. It will at times print one page then off again.
SOURCE: error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
SOURCE: I am still getting the error "Ink System Failure"
There is small patch that needs to be updated
Download & Install the patch from from here.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=nl&dlc=en&lang=en&cc=nl
SOURCE: Ink System Failure - Ink System has failed. Unable
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
SOURCE: Ink System Failure Error: Oxc18a0001
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: HP Photosmart C7280 - Error:Oxc18a0001
Hello.
Give this a try (from HP Support):
Solution 1:
1. Press and hold
"left arrow" key
3. Press
4.
display says "System Configuration Menu". 2.
button.
5. Display should
say "Hardware failure status". If not there already, Arrow Key over to "Hardware
failure status",
6. Press
and release the "OK" button.
7.
Display should say "Hardware failure status: Clear.
Press OK to clear".
8.
Press and release the "OK" Button. Message changes to
"Hardware failure status Cleared. Press Cancel to
continue".
9. Press and
release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure"
STAGE.
10. Using the
11.
the printer
12. Turn the
unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE
PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
14.
Installation.
15. If the
Solution 2:
Hope this resolves your problem.
