Question about Maytag Refrigerators
Both part of fridge are too warm. Top compartment
Both part of fridge are too warm. Top compartment is at 60 degrees F.
    Sergeant:
    Champion:
  • 216 Answers
Try checking your door gaskets,if not this the compressor is bad.
Posted on Jun 29, 2009
Samsung rb2055sl running warm 55 degrees in refrigerator and 70 degrees in freezer fan is working no ice, way to warm
Is there a clicking noise? Feel the compressor to see if too hot to keep your hand on top. Look ate the frost pattern in rear of the freezer compartment and tell me the results. Several things could be causing the compressor to get hot and not run. Freon leak is one thing that could happen and defective start relay, overload and run capacitor is another. You could also have a defective cooling fan under fridge or inside the freezer compartment
APPLIANCE 911
Sep 18, 2016 | Samsung Refrigerators
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
GE side by side. Top shelf in fridge warm. bottom drawers frozen. Freezer working fine. Seems to be blowing a lot of cold air out the vents by the floor. Top shelf in fridge is 55 degrees. Diffuser...
Hi, I'm Mark.
Check the position of the two controls at the top of the unit inside the fresh food compartment. SET BOTH controls to the 12 o'clock position. Wait about a hour, then check temperatures. Then wait another hour and check temperatures again. Record the values on a piece of paper. When you do check fridge temperatures, do so quickly as the compartments become warm just a few seconds after the doors are opened. Please let me know what happens to the fresh food readings.
Thanks, Best Regards,
Mark
Dec 29, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Fridge compartments too warm
There are several possibilities on your model. Compressor start components and Adaptive defrost Control. I would like you to pull away from wall and unplug , rempove the cover over compressor and feel the compressor to tell me if warm, hot or too hot to keep your hand there, Waiting for your response, Sea Breeze
Mar 27, 2010 | Jenn-Air JCD2389G Side by Side...
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Fridge side is warm at 60 degrees, ice build up at very bottom shelf next to vegies control, freezer temp. switch springs back when attempt to increase to level 3 or higher.
EASY FIX .TAKE ALL FOOD OUT.
UNPLUG FRIDGE FOR 24HOURS WITH DOORS OPEN .
CLEAN UP ALL THE WATER IT WILL LEAK ON YOUR FLOOR.
IT WILL WORK FOR ABOUT A YEAR OR TWO BUT WILL HAPPEN AGAIN.
A MORE PERMENANT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
May 01, 2009 | Refrigerators
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
Upper Fridge Too Warm
We had a warm fridge and super cold freezer.....we unplugged for about 20 minutes and the fridge started to cool down again.... but only for a few days then back to warm.
We ended up unplugging and "defrosting" the whole unit for 24+ hours ....Now it works perfectly again.
I think it happens when one or both of the doors is not shut or sealed all the way and engine works too hard and "freezes" up the fans or some other part of the system.......I am just happy I did not have to buy a new fridge.
Mar 30, 2008 | Maytag MB2262H Stainless Steel Bottom...
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
26 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
