POWER IS ON BUT FAILS TO WORK ANY CYCLE. CONTINUOUS BLINKING OF ADD DISH LIGHT.
SOURCE: RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
SOURCE: Kitchenaid dishwasher on the fritz, 5 yrs old pd $865.00
The part you need is the console, what happens is moisture gets into the 'keypad' and causes corrosion shorting out the trails. The keypad is not a serviceable part it comes complete with the console which is not too hard to replace. I can help you with that if you want.
The part number you need is 8574148, it also has substitute number of W10083998
You can try calling Kitchen Aid to obtain the part or look in the yellow pages in your area for an appliance parts dealer. If it were me I would try KitchenAid first you never know they may cut you a break since you are a loyal customer...... if you know what I mean....
