Question about Brother IntelliFax-1860C Plain Paper Inkjet Fax
I believe I have somehow "lost" the ability to send a fax. All it does is ring and then make the fax noise like it is picking up, but then the message will say, "TELEPHONE". and absolutely nothing will happen.
  • 313 Answers
Sounds like you have the fax set to tel mode or the cable is in the wrong connector check the entry point for the fax cable that it is in the line socket and not the tel socket also check that when you are sending the fax that it says load document as it might not be getting the paper set correctly so thinks you are doing a tel call.. good luck A
Posted on Jun 30, 2009
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
Does Windows 7 have the ability to send and
Well Yes, if you have a Modem, You can connect a Modem & then one can get software that you can use as a Fax machine. Also I believe there is a Built In Fax software too. However I recommend a third party setup. There are lots of really good FREEWARE Fax programs. Ensure they work with Win 7.
Feb 05, 2010 | Office Equipment & Supplies
My machine stopped recieving faxs.
Not familiar with the procedure to set your machine, so refer to your manual if need be, but somehow you machine has been chnged from "automatic receiv" to "manual receive", or "telephone mode".. Setting obviously needs to be "auto" for the machine to pick up on it's own.
Often times, this is a button right on the operation panel that you can toggle between the different settings.
Feb 24, 2009 | Brother Office Equipment & Supplies
Brother Intellifax
Not familar with MNL, does sound like you have the receive mode set to manual. set to auto anser or answer machine. In manual mode the phone will ring until you tell the fax to receive. In auto mode after so may ring which you set, the fax will pick up...
Aug 28, 2008 | Brother IntelliFax-2820 Laser Fax
FAx Line will not pick up or send faxes on HP 6110 All in One Officejet
it seems like you have lots of services on your line. here are the things that i want you to follow to somehow resolve the issue.
1. Press the setup button on your printer, then use the arrow down button to scroll down and go to ADVANCE FAX SETUP.
2. Press okay on Advance fax setup, then it will give you options.
3. The first option is DISTINCTIVE RINGS, press okay on that.
4. It will give you first option "DISTINCTIVE RING", scroll down and look for "answer on double rings" then press okay. then try letting someone send you a fax.
Note: make sure that your answering machine is using your home telephone line so that it wont affect the faxing functionality.
1. if the issue still not resolve, try to press setup, then go to TOOLS.
2. press okay on TOOLS and it will give you options, scroll down using the arrow down button and look for RUN FAX TEST.
3. Check the result of the test if everything passed!
Let me know if the issue still not resolve so that i can go ahead and give you additional steps.
thank you so much.
adonscott
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
My hp 2210 will not receive faxes
Ok the first thing you need to check is to make sure that you have auto answer turned on so that the machine will pick up when you are trying to receive.
There are alot of different factors that can effect your ability to receive a fax - see the link attached from hp's website and read about your specific setup. Things that can effect the fax would be voicemail, digital phone line, distinctive ring service, call waiting, the fax being plugged into a strong connection.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00036559&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
Feb 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
Incoming Fax Problem
Sounds like phone line issue to me like noise on it at times did your phone provider check it?
Dec 22, 2007 | Brother MFC-8840D All-In-One Laser Printer
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-1860C Plain Paper Inkjet Fax Logo
100 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
