Question about Garden
My Troy Built 2500 psi power washer with Honda engine GCV has been stored for 2 years. I changed the gas and could not get it to start. Which is the start position for the valve on the gas line - Horizontal or Vertical? Thanks, Bill Gray Melbourne Beach FL
  • 40 Answers
SOURCE: Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Posted on Jun 03, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
SOURCE: Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
Posted on Sep 01, 2009
mkh5094
  • 145 Answers
SOURCE: What type of oil is needed for a Honda GC160 Power
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Posted on May 28, 2010
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How to remove calcium buildup from pressure washer pump
I have found t vinegar has many uses. Mix the water with vinegar
Jul 09, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Last year around this time I tried to start my
Carburetor is probably gunked up from old gas left in system. It will need some cleaning and / or dissasembly.
Have it repaired at a reputable mower or small engine repair shop. When being stored for long periods, run it out of gas or use a fuel stabilizer in the gas to prevent this from reoccuring.
May 13, 2010 | Honda 2500 PSI Gas Pressure Washer
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
I can start it but then it quitsi i have a troy bilt honda engine power washer that will start but then quits what am i doing wrong
sounds like the fuel pump which are made cheap. Temporarily mount gas tank up higher should do the trick. I hung my tank on handle, to lazy to replace pump so left gas tank hanging works fine.
Aug 30, 2009 | Karcher 2500 PSI Pressure Washer
Do I need to add oil to the gas for a Troy-Bilt 2500 power washer
This engine is 4-cycle. It does not require oil in the gas. Is the crankcase full of oil? Do you know how to check it?
May 05, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
256 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
