I cannot find the "video and voice set up" in yahoo messenger that's why i cannot use my cyberlinkyoucam as my webcam
  • Computers & ... Master
  • 3,015 Answers
Once you have your webcam working outside of Yahoo Messenger you have to configure it to messenger.
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it.
Of all the chat programs, Yahoo has the most difficult software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) messenger > preferences > connection - select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > apply > ok
TESTING
> messenger > my webcam - warning panel will come on click 'ok' and your webcam will launch.
DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
PERMISSION OPTIONS
>messenger > preferences > webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam > actions > 'invite to view my webcam' this will launch an invitation on your contacts screen when they 'accept' - they will see you ( can check status on bottom left of webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
There is a shortcut ( cam picture ) in the toolbar and one down by your pic as well but these do not always work
your contacts needs to configure their connection the same as above or they may get a "webcam not connected" message
If you complete the above and still have problems - check to see if your cam is compatible with Yahoo
YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
open messenger > messenger > preferences > calling and audio - make sure your default mic and speakers are shown in the boxes
( the mic and speaker you want to use in messenger.) run through "call up assistant" > apply >ok
Posted on Jul 01, 2009
    Scholar:
  • 70 Answers
Yahoo! Messenger offers voice services, such as PC-to-PC, PC-to-cell or PC-to-landline calling. You can also participate in chat rooms and use the voice chat feature instead of typing. However, slow connection speeds or improper settings can interfere with voice activation in Yahoo! Messenger.
Instructions
  1. Step 1 Reduce echoes by using a headset instead of speakers and a microphone. Place the microphone farther away from the speakers, if possible. Adjust the volume of the speakers and the microphone.
  2. Step 2 Verify your Internet connection speed if your friend's voice sounds choppy. The computer modem speed must be 56K or higher in order to send voices or sounds.
  3. Step 3 Go to "Actions" and "Call Setup" in Yahoo! Messenger if you can't hear, or your friend can't hear you. Test the sound by following the instructions that proceed call setup.
  4. Step 4 Click on the speaker icon in the lower right corner of your computer screen if you want to test the sound manually. Uncheck "Mute," if necessary, and make sure sound levels are above 50 percent.
  5. Step 5 Pick "Preferences" in Yahoo! Messenger if you have trouble with connecting to the voice server. Choose "Connection," then select "No Proxies." Log in to Messenger again to check the voice server.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); For Webcam Setting
Having a webcam, or web camera, is a great way to share video images of yourself or whatever you want to show to family, friends or whomever you want. Being able to share your webcam on Yahoo Messenger can make it even easier for you to do. Learning how to change your webcam settings from your account informatioInstructions
  1. Step 1 Open Yahoo! Messenger and then click "Messenger," "Preferences" and then select "Webcam." Choose the option "When I show my webcam, change my status message to," and then enter whatever you want your status message to be in the text field. Then click "OK" to finish changing your status settings.
  2. Step 2 Choose "Webcam" from your Yahoo! Messenger "Preferences" menu and then click one of the following options, "Always ask my Permission," "Allow everyone to view my webcam," or "Always allow the following people to view my webcam." If you choose the latter you can select, from your friend's list, the people who you always want to allow to view your webcam. From there you can also select "Ignore other view requests," if you don't want to allow anyone else to view your webcam. You also have the option to either choose or not choose to select "If I am in a chat room, allow people in the chat room to view my webcam," by clicking the box. If you want to remove anyone who is viewing your webcam, you can select, "Who's watching me?" to remove their name from your viewers list.
  3. Step 3 Click "Webcam" from the "My Webcam" options in your Yahoo! Messenger "Preferences" menu, and choose "Statistics. From there you can figure out how much bandwidth you are using, as your connection mode, frame rate, image size and image capture type.
  4. Step 4 Select "Messenger," "Preferences," and "Webcam" from Yahoo! Messenger, and then click "Camera Settings." Move the slider under "Broadcast my webcam with," to select the between faster-speed transmissions or higher quality images. You can also change image size from this option as well as brightness and contrast. Click "OK" to finish.
n to creating contact groups is easy to do so that soon you can enjoy using your webcam on Yahoo! Messenger.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
must be login using any of your account on YM or try upgrade your yahoo messenger or download it again from the main site.
Posted on Jun 29, 2009
How to add a we cam to yahoo
Open Yahoo Messenger On the upper part of you yahoo messenger you will see "messenger, contact, actions & help" Select "Actions" Select "More Actions" Either select View Webcam or Invite to view webcam
Or for selecting a specific webcam to work for your Yahoo Messenger" Go to "Messenger" on the top part of YM Select "Preferences" On the category tab, select "voice & video" On devices go to "camera" & select your webcam that you will use.
Apr 05, 2011 | Yahoo Computers & Internet
Cannot use the video call and voice call ..im using the new yAHoo messenger
To invite somebody to view your webcam-->do the following -->login to your yahoo messenger account -->in the chat window go to Actions -->More Actions-->Invite to View my Webcam.
Jan 06, 2011 | Yahoo Messenger
I have an i mac but the cam when opened is black in yahoo messenger but when i go to my cam through applications to photo both my cam is able to work .
Make sure your yahoo messenger detect your cam source
in Preferences -> Webcam Broadcast -> Camera Setting and Camera Source
and test before you use it
Preferences -> Video & Voice -> Test Device
Dec 29, 2010 | Yahoo Messenger
Please help me to connect voice call and video call
first, make sure you have both the webcam and microphone set up and working. then click the Actions menu at the top of the Yahoo Messenger buddy list window, and you can select to start a video call or start a voice call with another yahoo messenger user who also has the needed devices set up on her end. hope this helps. feel free to rate or let us know how it goes for you
Nov 25, 2010 | Yahoo Messenger
What will i do to have voice in yahoo! messenger?
Actually yahoo messenger supports voice communication. Its enabled by default. You just need a Headset (Headphones and a Microphone). And you have to have Sound Drives installed and functioning.
With one exception, you can do voice communication. You cannot make Phone calls without buying credits. And Yahoo has limited support to Phone networks.
However you can do voice communication including Video (Videoconferencing) between two or More Computers. Its totally free of charge. You have to have a web cam in order to send your Webcam Live Videos.
You can adjust these setting after signing in to Yahoo Messenger. Go to Messenger and then Preferences. From there, you can adjust Voice and Video, Webcam etc.
Jun 15, 2010 | Microsoft Windows Vista Home Basic Edition
I have windows seven and my webcam works but will not connect on yahoo messenger. Please help.
  1. Download and install this latest version of Yahoo! Messenger 10.
  2. Verify that your computer has the latest versions of:
  3. Uninstall and re-install the software for your webcam. Go to How do I re-install my webcam? for instructions on how to re-install your webcam software.
  4. Check your webcam’s compatibility with Yahoo! Messenger. Go to How to Test Your Webcam for Compatibility with Yahoo! Messenger and follow the steps provided in the article.
  5. Use the Video and Voice Setup assistant to test your webcam, here’s how:
    1. Click the Yahoo! Messenger Help menu and select Set up Video and Voice.
    2. Go through the three step process to test your microphone, speakers, and webcam..
May 30, 2010 | Computers & Internet
My yahoo messenger voice call pc-pc working but the other side can never hear me! But if I use skype no problem. It used to work but may be because I changed my wireless router to Belkin! But I also turned...
Try running through your settings again
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger 10
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Video and Voice
Set webcam mic and speakers to show Default equipment
Open Video and Voice Setup to test audio equipment
Click 'Place a free test call'
Check box 'Allow USB devices to access Messenger'
Click 'Apply' click 'OK'
May 15, 2010 | Yahoo Messenger
No audio with lifecam vx5000
Go to the microsoft website - fill in your details to navigate to the help page for your model - check out the 'readme' link especially the 'known issues and breaking' section - some later lifecam webcams require additional software or specific to IE
TEST SPEAKERS
Restart computer
Mar 27, 2010 | Microsoft LifeCam VX-6000 Webcam
Dell 15-Built in webcam de-synchronization with Yahoo Messenger
My friend, try to set your webcam to a little resolution, yahoo is not for quality videochat, but if you wanna quality on videochat, please feel free tu use Skype! PLease rate me if i have help you! Thanks!
Sep 14, 2009 | Dell Studio 15 Laptop
Yahoo messanger voice service is not working
Dont use yahoo messenger for ACER ASPIRE ONE not compatible, I suggest use SKYPE messenger text chat, video and voice call as well work great.
Yahoo messenger work only video and text chat only but voice call not work.
Skype messenger works video and voice call works perfectly.
Nov 23, 2008 | Yahoo Messenger
Computers & Internet Logo
248 people viewed this question
David Payne
David Payne
