Question about Samsung Fino 115s 35mm Point and Shoot Camera
This is the problem and a fix. If your 115s will not keep the lens extended in the ready to shoot position, prise off the sliding lens cover with a thin blade. You'll see a little black 'rocker' which is usually hidden under the lens cover.Try gently easing it up over by rocking it with your thumb with the little latch moved fi-urthest away from the lens. The lens should be in the ready to shoot position. If when you let go the lens pops back in, try cutting a sliver of a rubbe bansd and work it in to the small channel at the bottom rounded end of the rocker so you move the rocker up about a mmm. Make sure the sliver of rubber band is snug and not proud of the surface of the little channle. Test by rocking the rocker back and forth until you're happy the lens remains out when it should. Rock the rocker back to the closed positiion and reattach the lens cover. Treat yourself to a few opens and closes as you feel good about fixing it yourself. Mike.
  • 3 Answers
Please see the solution posted above
Posted on Jun 30, 2009
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Lens protective cover won't close after I dropped it.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 30, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Lens cover won't close and there is internal dust
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
Apr 16, 2009 | Canon PowerShot A560 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Fuji a345
Simply wear and tear.- dirt ingression- damage from a knock- nothing you can do about unless you are a watchmaker. A repair will be as costly as simply replacing it Check out Fuji support though to be sure.
Aug 15, 2007 | Fuji FinePix A345 Digital Camera
Cover open, unable to take a picture?
The cover opens in two positions. To completely open the lens cover for shooting images, slide the lens cover over until you hear two clicks. When the camera is on the first position, you can playback images.
Sep 01, 2005 | Olympus Camedia C-40 Zoom Digital Camera
Open cover
Aug 31, 2005 | Olympus Camedia D-510 Zoom Digital Camera
Cover open
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
Samsung Fino 115s 35mm Point and Shoot Camera Logo
136 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
