Question about Singer Featherweight 132Q Mechanical Sewing Machine
Adjusting the bottom tension on a 1938 singer featherweight
I recently brought out my machine to oil it and use it to quilt - after oiling the machine the bottom tension thread is too tight - how do I solve the issue. Please help!
    Scholar:
  • 110 Answers
If the bottom tension is too tight, the problem lies with your top thread. Lower your top thread tension and it should rectify your problem
Posted on Nov 14, 2007
Stitches too small
TIP: A general rule of thumb is that if the stitch looks bad on the top it is the bottom tension.
If the stitch looks bad on the bottom it is the upper tension. The upper and lower threads play
tug of war with each other.
Tension
You need correct tension on the top and bottom threads, but you must also have correct tension on
the quilt held between the rails. You should have a small amount of "sag" in your fabric. This allows
enough movement of your quilt layers for the needle to penetrate and make good stitches.
Before you start making adjustments to your machine ask yourself, "What changed?" If your machine
was stitching great and all of a sudden it has loopies on the back or puckers, "What changed?" Did
you just change the bobbin? Did you just lift the take up rail? Did you lower the take up rail after
finishing your last quilt? Did you recently change the needle? Did you just roll the quilt?
If the take up rail with the quilted portion of your quilt is too high, it will result in poor stitch quality. You
need a finger tip space between the quilt and the machine bed. Higher will result in poor stitch
quality, too low and the quilt will create a drag on your machine's movement.
Look at your bobbin, a sloppy wound bobbin will not create a good stitch. Make sure that the threads
on the bobbin are snug and evenly wound. Check to see if there is a piece of lint in the bobbin case
Dec 19, 2016 | Sewing Machines
Thread gets caught in the screw behind the thread take-up lever
Is this your Model here
  • tension disks ( the coil/spring ) needs to be replaced
Sep 25, 2008 | Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Adjusting tension when stippling
Yes you should lower the feed dogs for free motion sewing. The tension can be set higher as required. A perfectly tuned up machine uses a setting of 5 but don't be afraid to go higher to get rid of the looping on the bottom.
Also, oil your hook every 8hrs with Pfaff hook oil (which is lighter weight than regular sewing machine oil) if you have it, otherwise use white sewing machine oil. Looping on the bottom can be caused by a dry hook.
good luck!
Feb 01, 2009 | Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Singer Featherweight 132Q Mechanical Sewing Machine Logo
111 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
