Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ok got the new thermo in and it cycled and started thawing- still has not gotten cold enough to freeze water. fan in freezer is blowin hard condeserfan is also runnin right along. checked the heatine elements last time thye were workin- removed back panel to find frost on the lower coil only- seems to defrost once/day?
  • 2 more comments
  • brant5 Jun 30, 2009
    this machine is abouttenyears old- the 3 lower coils were frozen up- determined the defrost thermostat was bad- it has been changed- the heating elements work but the lower coil is still frosting up and the fridge and freezer are not cold- the upper fan is blowin and the condensor fan are blowin the coils have been cleaned. id like to understand the system so that i can check through thanx
    thanx ill try toi check out the links,in the mean time..this is a newer non freon unit, it doesnt seem to be getting cold enough to cycle off and this lower coil in the freezer is freezin up- in the ol days it would be low on freon and need a charge,firts fella said it was dehumidifier- what the - a fridge is a dehumidifyer. im ready 4some hep- thanx in advance
    here we go- fridge about ten yrsold- coils were freezin up in the back of fridge- deterimed the defrost thermostat was bad- replaced it- still have the lowest coil frosting over and the fridge and freezer are not cold enough. both blowers are working undercoils are clean defrost heat elements working
    is there a proper way to defrost? I washed the lower coils opened the coils in the freezer- added hair dryer- till ice was off and plugged her in. ifn it are all fubnctioning but aint cold enough why is this a death sentance??? thanx
  • 82 Answers
If only part of your coil is frozen it sounds as though you may have lost some of the charge or your compressor has lost its efficiency with age. You said the condenser fan is running, is the condenser clean? Give it several hours to run before you condemn it. You have nothing to lose by waiting. Defrost timers usually cycle on compressor run time not just on a schedule as such.
Posted on Jul 01, 2009
    President:
  • 392 Answers
After looking through the old solutions and the process you have done , there is nothing much more left that we can solve the issue. The only thing is to Buy a new one. anyway as this is 10 years old i think it would be better if you go for a new one. If defrost is done properly then it may work, but even u said that u already changed the defrost thermostat. so that is not the problem, anyway i suggest is go for a new one. Even if u solve it, it will work temporarily and after few months it will again get some more problems, so it is also a waste of money and time , so better to go for a new one.Plz rate my answer
Posted on Jun 30, 2009
  • 294 Answers
There R 2 things that need 2 be known for refrigeration.
1. A gas cools on expansion.
2. When u have two things that r different temperatures that touch or r near each other, the hotter surface cools n the colder surface warms up. This is a law of physics cald the Second Law of Thermodynamics.
Old Refrigerators
If u look at the back or bottom of an older refrigerator, you'll see a long thin tube that loops back and forth. This tube is connected to a pump, which is powered by an electric motor.
Inside the tube is Freon, a type of gas. Freon is the brand name of the gas. This gas, chemically is called CFC. This gas was found to hurt the environment if it leaks from refrigerators. So now, other chemicals r used in a slightly different process (see next section below).
CFC starts out as a liquid. The pump pushes the CFC through a lot of coils in the freezer area. There the chemical turns to a vapor. When it does, it soaks up some of the heat that may be in the freezer compartment. As it does this, the coils get colder and the freezer begins to get colder.
In the regular part of ur refrigerator, there r fewer coils n a larger space. So, less heat is soaked up by the coils n the CFC vapor.
The pump then sucks the CFC as a vapor and forces it through thinner pipes which r on the outside of the refrigerator. By compressing it, the CFC turns back into a liquid and heat is given off and is absorbed by the air around it. That's why it might be a little warmer behind or under ur refrigerator
Once the CFC passes through the outside coils, the liquid is ready to go back through the freezer and refrigerator over and over
How Does the Temperature Stay the Same Inside?
A device called a thermocouple (basically a thermometer) can sense when the temperature in the refrigerator is as cold as you want it to be. When it reaches that temperature, the device shuts off the electricity to the compressor.
But the refrigerator is not completely sealed. There are places, like around the doors and where the pipes go through, that can leak a little bit.
So when the cold from inside the refrigerator starts to leak out and the heat leaks in, the thermocouple turns the compressor back on to cool the refrigerator off again.
That's why you'll hear your refrigerator compressor motor coming on, running for a little while and then turning itself off.
Today's refrigerators r very energy efficient. Ones sold today use about one-tenth the amount of electricity of ones that were built 10 years ago. So, if you have an old, it's better 2 buy a new 1 cz you'll save money (and energy) over a long period of time.
belo are few links that shall help u understand system betta..so dat u can fix it ur own
  • How Stuff Works - Refrigerator (www.howstuffworks.com/refrigerator.htm)
  • Science Treasure Trove - refrigerator page (www.education.eth.net/acads/treasure_trove/refrigerator.htm)
Hv nice time>>>>>>>>>>>cheers!!
  • 483 Answers
Its the dehumidifyier, if its a new machine i do not see why would it not defrost the coil.
please make sure if not a defective part (under warrenty i am sure) ...
No, its not suppose to defrost once a day..
Thanks
Fame !
Refrigerator part not keeping cold- freezer freezing. I unplugged it . Cleaned the freezer and thawed it out. It seems ok but the refrigerator part is not cold.
There is a fan that delivers cold air from freezer to the fridge section. if freezer is working fine, and fridge part is not cooling replace the fan motor/fan
Dec 29, 2016 | Refrigerators
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I've had this problem before, where the fan is frozen so the fridge is no longer cold but the freeze is OK. What the guy did last time was remove the floor of the fridge, and poured hot water on the fan...
fridge not going into defrost, freezing up coil, replace defrost control, should thaw out fridge, or your evaporator fan motor is burnd out, thaw fride first see if fan works, if fan ok ,derost timer, if not relace fan motor
Sep 06, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
Freezer works fine but fridge portion is not getting cold enough
by any chance do you hear the fan on at all........reach into the top freezer and feel if any air is blowin out of the vents..........if no air blowin it might just be the fan motor......it might be defective........................more details would be good..................
Jun 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
Jenn Air ref/freezer not freezing/cooling
Take the back out of the freezer and check and see if the refrigerator is in defrost while it is cooling if it is replace the timmer, then check and see if the fan on the underside is working if not replace the motor this will cause the problem also.
If all that is ok feel the small line under the refrigerator ( high side) and see if it is hot while it is running if not check the freon in the refrigerator.
Mar 03, 2008 | Refrigerators
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
