Question about Oster 76076-010 Hair Trimmer
I am in need for a replacement part for our Oster Power Pro Cordless Clipper. I don't know the name but it is the little part that moves back and forth under the blade. When it is in need of replacing the blade does not cut evenly or very well at all.
  • 193 Answers
White plastic piece is called Drive Assembley we have stock of this item please contact us to order.
Posted on Aug 07, 2009
  • 22 Answers
SOURCE: Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Posted on Feb 02, 2009
SOURCE: Oster A5 single speed clipper not cutting
not usually we will not sharpen blades that are worn out as we cannot charge for something that does not cut!
make sure your blade is connecting with the drive of your clipper they might need an extra push depending if the blade has been adjusted.
Posted on Sep 06, 2009
philschneide
  • 448 Answers
SOURCE: Blades do not function
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever. Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon carries both single speed and 2 speed gears under Oster A5 clipper parts.
Good luck.
Posted on Sep 30, 2009
philschneide
  • 448 Answers
SOURCE: CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
Posted on Apr 09, 2010
SOURCE: Simple question: Are the Oster 76 2-speed, the
well the 76 and the golden a5 are almost the same the name plates are different and the 76 uses a toggle switch but the a5 uses a rocker switch. not sure about the crewmaster sorry.
Posted on Sep 27, 2010
Will an Oster A5 blade work???
Yes if you have a clipper compatible e.g Andis Agc or Oster A5, power pro ... need a little more info
Feb 26, 2016 | Oster Health & Beauty
Instructions oster power pro cordless clipper
go google and see if there is a workshop or user manual for the clippers
Jun 26, 2017 | Health & Beauty
I am looking to buy 2 new batteries for my power pro clippers model 48951-005, where can I buy them?
I too need the same batteries but Oster stopped making them and now if you want a battery to fit the female part of you set you need to buy a new battery with a new gizmo at the price of over $150 Making what you have worthless and making what you need cost more than two old batteries or a new machine all together. Its a real rip-off.
Sep 18, 2012 | Oster POWER PRO Cordless Clipper 76600-013
Oster Blade 918-306 Size Texturing Fits Oster Classic 76 Clipper, Power Pro, Power-teq And Star-te: Oster class 76 clippers....had them for a week and...
70ca16d.jpg Hope this helps, this is a tongue guide, you hopefully recognise it on your blade. If they are not paralell, then adjust them with pliers, both need to be perfectly vertical. When you put it on the clippers push the latch in as you close the hinge.
If it still wobbles then the next fe wthings need checking
1. The hinge screws on the clipper are tight, located either side of the hinge on the clipper.
2. The drive lever may be worn, thats the maroon peice of plastic sticking up at the top of the clippers, it moves from side to side when clippers are running.
3. If all seems fine up to now, your clipper should be fixed under warranty as it will involve changing parts covered by the warranty.
www.sheareaseltd.com
May 17, 2010 | Sunbeam Oster Blade 918-306 Size Texturing...
Motor burnt out on oster A5 clippers. Are replacement motors available and if so how much are they please?
It sounds like you know pretty well what you're doing and mainly just need parts then. I suggest clipperparts.com. They are the kings of clipper parts and very knowledgeable if you need a little extra help
Jan 19, 2010 | Oster Golden A5 1-Speed Universal Motor...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
How long to charge cordless battery for Oster Power Pro Ultra
Usually it is recommended that you leave it plugged in to charge a minimum of 12 hours before you even use it. Then, once you unplug it to use it, keep it completely unplugged and use it until it dies completely and shuts itself off. Then, and ONLY then, plug it back in and charge it again for a minimum of 8 to 12 hours and do not use it while it is charging! Once you've passed the 8-12 hours, you can unplug it again and start using it again. After you do that, you should be able to use it for a few days before it dies and you will have given the battery a "memory". After that, you don't really need to have it plugged in more than a few hours to fully charge after being drained. It's always best to let the batteries fully drain and shut off before plugging back in to preserve it's life.
Mar 30, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76
change the carbons
May 25, 2007 | Oster 76076-010 Hair Trimmer
Oster 76076-010 Hair Trimmer Logo
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
