Question about Nokia N73 Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
On an incoming text , I've no way of knowing that I've received one, unless I go to the inbox and see a red star beside the message inbox icon. I have no tone, vibration, or message envelope in the top right hand corner whilst receiving a text. I've checked profiles and there's nothing obvious wrong.Incidentally, I've lost delivery notification also, and don't know if these two problems are related.
I've changed the sim card to a different phone and it works perfectly .Untill yesterday everything worked fine on my N73.I know it's something small.....
Any ideas? Thanks in advance. Mick G.
  • 6 more comments
  • ChristophA Dec 06, 2007
    i got the same problem, no message alert, but am worried if i do a master reset will it delete all my messages contacs images etc???
  • MichelleN Jan 22, 2008
    Hi I have the same problem but even when I change the text settings back to phone memory it still does not work.... any ideas?
    Thanks!!!
  • Anonymous Aug 28, 2008
    no alerts... after doing reset twice.... :(
  • shery_masti Sep 08, 2008
    my problem is exactly the same...there is no vibration,,,noalert...to tone,,no msg envelod on top...
    plzz some one help me...n others as well...i know its not a big problem..but still im fed up by checking my msges..i have to check my inboxes red star...all the time..plzz some one plzz help me..
  • Anonymous Sep 08, 2008
    hallo wer bis du
  • Anonymous Nov 04, 2008
    ya i too have the same problem, finally i found out why this is happening..
    When you send more than 65 msgs within 2 hours this wil arise,,
    Even after formatting it will come/
    This is not the problem only in n73 but in all s60 v3 phones
  • Anonymous Jan 05, 2009
    same problem....no alerts...no new tones coming even when changed....no vibration!!!!!!!!
  • raj100784 Feb 04, 2009
    i have the same problem, no message alerts no envelop icon, i need to check the red star beside inbox icon regurlarly. i have cleared my inbox now. but the problem still exist. does anyone having a proper solution to this problem?
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Posted on Sep 09, 2009
  • mcgrathjoan Aug 28, 2010
    Thank you, thank you, thank you :) I have my alert tone back x
  • abc7978 Mar 14, 2011
    superb...it worked....thanks a lot..
The reason for this is because you have too many text messages saved in your inbox. Delete them all and then change the alert tone, then switch the phone back off and on again.
Problem solved.
Posted on Aug 28, 2008
Hi. I had the same problem, and I fixed it by changing the storange messeges from my cellphone memory to the memory card memory. That just solved my problem
Posted on Jul 27, 2008
I removed my memory card and then switched on my cell.... after that i again switched off and inserted the memory card and switched on and i started getting the alerts
Posted on Mar 19, 2009
I had the same problem.. all i did was go to tools then into profiles. pick the profile you want.then press options then personalise. scroll down to message alert tone.press select and pick the one you want from the list..
Posted on Sep 23, 2008
When i turn on my phone it dosent vibrate also when i get a message or an incoming call it still dosent vibrate can some one tell me how to fix my vibration i reseted my phone 4 times still no change even i tryed turning on the vibration still no change with the incoming call alert vibration so pls some 1 tell me what to do :(
Posted on Sep 22, 2008
I had the same problem. Go to the profile and change the message tone to the ones saved in ur phone, then try and send a text message to urself. If it works then go back and set the message tone back to whichever tone u want....
---naughtydude
Posted on Feb 25, 2008
I was able to fix my phone using doing a reset. The first time I tried, it did not work so I had to do a reset twice. However, I did lose some stuff from my phone even with the backup. I'm just glad I got the tone back. Thanks to everyone who responded. :)
MichelleN
    Problem Solver:
  • 11 Answers
Find your solution from the list,
Nokia N73
Codes:
Software & Hardware Problems
Find Your Solutions for other Nokia Phones:
Nokia N95
Nokia N70
Nokia 6300
Nokia 6600
All the other Nokia Phones.
Posted on Jul 28, 2010
I'm not very sure how i did it. But i figured out it has something to do with the things inside your phone memory. i resetted my phone and the incoming msg alert appears again. but when i put all the files that i've backup from my PC to my phone, the alert is gone once again. ya, so i dunno wat is the exact problem, but it has gotta do with the phone memory.
Posted on Feb 04, 2008
I found that the best way was to just fix it.
Posted on Mar 31, 2008
Hi All,
Even I was facing the same issue from the last 1 week or so...I have now sorted out the issue by
deleting the messages from Inbox.
Looks like this issue comes up when the phone messgae memory is crossing some mark.
Interestingly I also noted
that this problem surfaced
when I sent bulk messages to my friends..so guys
be careful when u r sending ne bulk messages.
Hope this helps.
Divyendu V
Posted on May 21, 2010
Why in N73 The New Massage Popup not Show The Sender Name How Can I edit the text of popup box liki
New Massage Recieved From <Sender Name>
pls help me.
Posted on Mar 04, 2010
Thankyou for your help everyone. i went into settings, phone settings, general, personalisation, tones then changed my tone to a nokia tone. restarted my phone, lost no data then you do the same as above going into your settings and changing back to your original tone before the mobile faulted. once again thankyou everyone for your help and support, it was greatly appreciated!
Posted on Jan 13, 2010
I solved this by resetting the 'Orig. phone settings' [Menu-Tools-Settings-Phone-General], it doesn't delete any data and only took me a few minutes afterwards to change back things like ringtones etc..
Posted on Dec 11, 2009
Im also having the same problem..i dnt get alert that i got a msg..i have to go to inbox to check whesther i have a msg or not..i tried by master reset...it works..but when i restored my phone memory back up file from PC..the problem again occurs..so plzz help mee....
Posted on Sep 08, 2008
  • shery_masti Sep 10, 2008
    come on people..plzz help me with this proble..my cell phone is not alerting me that i got a new msg..plzz guyzz help me..plzzz..i know its not a big problem..
Posted on Sep 06, 2008
I am unable to change massege tone .....not by defult in in fone ,,,,,my selected Tone want to change,,,,,plzzzzzzzzzz help me any one ,,,,, can i change my liking tone..............
Posted on Jul 24, 2008
None of the above solutions worked for me. However the answer was kindly posted by someone else on Fixya with a similar problem. Press star,green button[send],and 3 and hold whilst powering up your phone.You need to back up your contacts as this is a default setting and you will lose them.
Many thanks to one and all who tried to help. You're not a bad lot out there!
Mick G.
How do you do a master reset?
Posted on Feb 14, 2008
Use the alert tone from phone memory instead. Do not use the tone in your memory card. It managed to fix my problem.
Posted on Dec 20, 2007
    Sergeant:
  • 316 Answers
Try a master reset this should return phone to factory defalt settings.
Posted on Nov 08, 2007
The message inbox says I have 1 new message, even though I have deleted all messages and there are no unread texts. It also displays the small envelope icon on the main screen in the bottom left corner,...
go to the mesage tab and click options then search for the option on the sim mesages and when it opens delete all the messages in the sim message box and check whether any messages in the outbox
Jun 23, 2011 | Samsung Renown Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Can i make any of my ringtones be the tone for incoming texts and also, can i use animated wallpapers that actually move?
you can download animated themes at www.mobile9.com and www.zedge.net for your e71 phone. as for the ringtones, yes, you can use these tones to be the the incoming tones of your text messages. go to setings, profiles, general,choose personalise, message alert tone and choose your favorite aac or mp3 tone to be your message alert tone.
Nov 02, 2010 | Nokia E71 Smartphone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
How can I set repeat incoming text alert tone till text is read.
this should be in sound setting its absending you want set it on
Aug 14, 2009 | Cell Phones
SMS not opening
I'm also face the same problem with my nokia. this things happening when your memory card get corrupt. you can avoid this trouble temperally formating your memory card. after that problem persist change your memory card to a new one.
Jul 20, 2009 | Nokia N95 Cellular Phone
Icon identification on text messages inbox
it means the message saved to your SIM card, not your phone.
May 06, 2009 | Samsung Gravity SGH-T459 Cell Phone
Boss moans at the VOLUME of my message alert
Try to go to Userprofiles --> General --> Customize --> Tone setup --> Message tone.
Thanks,
Mar 26, 2009 | Nokia N73 Cellular Phone
Motorazr V3 Status indicator no longers displays envelope for voice messages
Why am I receiving a memory full notification? space.gif space.gif answer.gif Memory full warning notifications are shown once the SMS memory reaches 80% full, which is 80 out of 100 SMS.
The notifications show up every time on receiving a new message. On reaching 100%, "Memory full notification" message is shown and no new messages will be received until we make space for incoming messages by deleting some from the inbox.
Memory full warning notices are shown only if "Auto Erase Inbox" is set to Off in Messaging settings (Menu -> Settings -> Messaging).
If set to On, then these notices are not shown. By default this is set to Off.
Oct 22, 2008 | Motorola Mobility RAZR V3
Nokia N73 Cellular Phone Logo
4,865 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
