Question about GE GSS25SGMBS Side by Side Refrigerator
GE Side-by-Side PSC23NSTCSS -Conrol Panel is not showing anything
My GE Profile Side-by-Side Refrigerator PSC23NSTCSS has stopped working. The lights are on, however the Conrol Panel is not showing anything and not taking any input. There is flashing on the "Custom Control" display once every sec illuminitating the HRS letter. The water dispense system is also not working. Please help.
Sea Breeze
  • 4655 Answers
SOURCE: Ge Profile dispenser panel
Here is a link that will help give you a step by step process of elimination, click below and insure you have the correct model numbers as you move through the process, Thanks Sea Breeze
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Oct 27, 2007
  • 90 Answers
SOURCE: the letters hrs are blinking on the temp control panel
Unplug for 3 minutes. Plug back in see what happens.
Posted on Jan 05, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
  • 74 Answers
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
SolutionGuy
  • 331 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Posted on Apr 01, 2009
GE Profile pss27sgrss has a bad main pc board
Yes I would agree that you get another refrigerator! The GE PSS27SGRSS is an Artic/Profile model and people have had nothing but complaints about the motherboard problems. I recommend you buy something that has no motherboard or electronic defrost. The best refrigerators out there are ones that have the simple defrost timer and no electronics, Thanks Sea Breeze
Dec 05, 2012 | GE PSS27SGRSS Side by Side Refrigerator
MY GE PROFILE REFRIGERATOR DOES NOT COOL IT SHOWS 7 ON THE DISPLAY AND THE REFRIGERATOR SECTION DOES NOT FREEZ ANYTHING IT SHOWS 4 AS TEMPERATURES.
ck the fans and clean the coil underneath / dirty coil will cause poor cooling and fan that is not going or is going too slow .. mm
Sep 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile refrigerator panel on front has stopped responding to requests for ice. It give water, but no ice. Any ideas on what is needed?
Yes, we will need to check the wiring from the motherboard to the dispenser controls. Also we need to test the door switch. The door light switch works two ways by turning on light when open and turning on dispenser controls when closed. Sometimes the door switch is bad. I have a link and will work with you to solve this, Let me know, Thanks, Sea Breeze
Apr 18, 2010 | GE Profile PSS26NGS Side by Side...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
Oct 26, 2007 | GE Profile PSI23NCR Side by Side...
GE GSS25SGMBS Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
