Question about Sharp Microwave Ovens
The microwave is a sharp model is r23bp and this a commercial microwave it doesn't have display this one has only numbers 1,2,3,4,5,6,7,8,9,0 and there is a led light on number one after I put a third load it doesn't heat it only blinks number one. And If you touch the top cover it's really hot I have clean the filter wich is under the unit. but before this happen I've changed the secondary interlock switch because was toasted.
  • William Miller
    William Miller May 11, 2010
    Model: R-23BP, R-23BT Symptom: Digits on right side of
    display are flickering Problem: Capacitor C5 on main printed
    circuit board is either defective or has bad solder joints Solution: Replace C5 (470 MFD 35V)
    or repair solder joints as necessary Let us know what you find. Feel free to contact me directly (and please remind me of your
    full model number from the tag on the unit) for more information & help.
    William E. Miller, AS-EET
    prototech@usa.net http://www.microwavedisplay.com
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Microwave Oven
Quite often this is due to grease or food particles stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
If you need further assistance, please feel free to contact me directly through the links at our site: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
  • 4088 Answers
SOURCE: Sharp Microwave stopped working. lights up, counts down. Fine'
High voltage power supply for the magnetron is likely problem. Multi-thousand-volt section--be careful.
Posted on Jul 12, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a F6 error
F6 on these models means that the cook relay on the control circuit board is shorted, and it is cooking anytime the door is closed.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you prefer, you can buy a new circuit board (part number 8169733 for $150.27) from the Pros
here.
They're our favorite supplier.
Posted on Sep 08, 2010
SOURCE: unlocking child lock on the sharp microwave model R316FSC
The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
Or just unplug it, wait 1 minute, and plug in.
Posted on Jan 02, 2011
Why won't my microwave oven work?
No, it's not worth the effort required to replace the control module - unless it is a commercial model.
May 25, 2014 | Sharp Microwave Ovens
What is the color of the sharp r-1480?
The Sharp model numbers indicate the cabinet color by the last number in the model number. 0=Black, 1=White and 2= Almond
Apr 18, 2014 | Sharp R-1480 Microwave Oven
ERROR EE8 ON SHARP 24AT
R-24AT is a UK model, and I'm in the US, so I can't give you detailed, specific part number info.
But in the Sharp commercial microwave manuals I have, it says the EE8 error means you have a shorted relay.
I would assume that's one of the cook relays on your controller board.
Here is the US, we have R-24GT and R-24GV models, and they may be similar enough that their service manual (here) will help you some.
But if you need further parts or service help, I would suggest contacting Sharp UK support here and here, respectively.
Good luck.
Dec 10, 2012 | Sharp Microwave Ovens
Display panel shows E01 and bleeps continuous
A model number would help, but one Sharp commercial manual lists these codes as close to what you typed:
"EE1" Magnetron (1) failure. (could be one of many parts in the magnetron 1 circuit)
"EE0" Fan lock judge.
"EE10" Intake thermistor is shorted.
FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted, so please post a new help request with your model numbers and precise symptoms.
William E. Miller
prototech@usa.net
May 27, 2010 | Microwave Ovens
The microwave screen says EE2
The fault code "EE2" on a Sharp commercial microwave oven means that the magnetron 2 circuit has a problem and is pulling too little or too much current.
It may be the magnetron, high voltage transformer, high voltage diode, wiring, etc.
Since you didn't mention your model number I can't say for sure, but magnetron 2 is usually the lower magnetron in a Sharp.
You can order Sharp commercial microwave parts here.
If you need more help, we may have the service manual for you to download free.
But we would need the model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So to allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit and your symptom, "EE2" code.
Dec 25, 2009 | Sharp R-1500 Microwave Oven
Error code ee1 on sharp r-22at
EE1 on a Sharp commercial microwave is magnetron 1-related failure.
It may be a bad connection or relay on the control board, a bad magnetron, a bad high voltage diode, etc. - anything in the high voltage circuit for the #1 magnetron.
We have the service / repair manual for a similar model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips, but do not rely on the part numbers shown in that manual.
You can find part numbers and order parts from Encompass here or you can call them toll-free at 866-779-5835.
Most computers will open the manual automatically, but you may need the free Adobe Reader
Jun 07, 2009 | KitchenAid KHMS2050SSS Microwave Oven
Unlocking child lock on the sharp microwave model R316FSC
Jan 06, 2009 | Sharp R-308J Microwave Oven
Sharp microwave model R-510AK led screen only showing parts of numbers programed
This is a common problem. i havent completly solved it yet but this helps.
Be very careful doing this, There is Voltages with AMPERAGES high enough to boil your blood inside a microwave.
I had mine apart cleaning it. Only one number worked on my display. I wiggled and messed around with the wires in the back of the display. And almost every number in the display works again. Hope this helps.
Oct 20, 2008 | Sharp Microwave Ovens
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
Jul 03, 2008 | Sharp R-230 Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
