Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Lost internet access after power failure
I have a d-624 wireless router that failed after a power failure.In order to access the internet on my desktype computer i had to disconnect the unit ,So currently I don't have Wireless in my house.How can I remedy the situation?
    Genius:
  • 1,269 Answers
Hard reset the router first by pressing the reset button at the back of the router for 30 seconds. Reconfigure it using the setup CD. If that didn't work, you need to call D-Link support to check if the router is dead or not.
Posted on Jun 30, 2009
DI624 will not work. All 4 LAN lights permanantly on with no cables connected
Yes it could be faulty, especially if it the router is not protected with a surge protection power board.
Jan 22, 2013 | D-Link DI-624 Air Plus XtremeG Wireless...
I have internet connection through the modem but the DI-624 router will not allow an internet connection.
If you had a USB or Wireless card and your router have slots to plug them on, it you can set your router to work as an "Access Point"
Oct 04, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Lost software how do i get another one
This is NO software as such as it is all built into the router, simply access router properties by typing the router address (192.168.0.1) into the browser.
Jan 07, 2010 | D-Link AirPlus Xtreme Super-G DI-624...
DI-624 always lost connection after use about 10mins. to 20 minutes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 16, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Dl 624 wireless not authenticating
Try to MAC Cloning first. Open the router's admin page and look for MAC Address Clone setting. Enable it and save. You must power cycle the router and the modem after that.
Jun 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Re-installing DI-624
Access the configuration page of your router by default its 192.168.0.1, Login to the Dlink page by default the Username is Admin and Password is Blank and then reconfigure your router for Internet connection.
Dec 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
No wireless signal
This can be a problem with the wireless settings of your router, that is configured correctly, if you know how to access the router setup page that's where you can configure and check all the settings and also change some settings of the router in order for it to work and provide wireless signal, but if you're not familiar with better call Dlink so one of their tech support can walk you through with that process.....
Hope that helps.........
Sep 04, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Need help with connect a d-link,dl 624 router
You wireless router/access point can host several simultaneous connections to the internet. Just connect your laptop to the wireless network as you would from your desktop computer.
Hope this helped.
MO
Jul 11, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Unable to access the set-up wizard to install my wireless router.
just reset the router... do you know how?
there is a small hidden button on it that you must press and hold for some minutes firs with the router powered and then with the router not connected to power line... Try this at leas 2 times with and 2 time without power, then try accessing the router as if it were new... with the default pass that comes in the manual...
Mar 03, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Di-624 stopped working
Hi sailaway!
. Make sure the router is going from the modem, to the port marked WAN, on the 624. You can test the cable, by plugging it directly into you computer, from the modem, if you want to. Disconnect the power from your modem, your router, and turn off your computer Wait 1 min. Turn on the Router, wait three full min's. Power up the 624, and wait one min. Power up the PC. Reason for the long wait on the modem is that it has to get data from the internet, to give to the router. If that don't hwlp, try changing the cable from the PC to the router, to a different port. If all that don't work, try resetting the router by gentley pressing a straightened out paperclip into the reset hole in the back. Hold it for 30 sec. If that fail resetting it, try holding it in while you unplug the 624 and plug it back in. If it resets, go thru the first steps to set it up again. If all that fails, your 624 may be bad. Had that happen to me. The steps I listed brought it back to life for about 2 months, and it died completely. Good Luck!
Jan 05, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
330 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
