Question about GE GSL25JFPBS Side by Side Refrigerator
GE GSL25JFPABS- Icemaker not producing ice. Performed self test as instructed by GE. Ice make cycles as it should and refills with water. Could motherboard be problem? Have checked all connections and replaced filter with bypass, still no ice.
  • 54 Answers
SOURCE: ge icemaker problems GSS25LSWASS
What part was installed?
Ensure that the Ice Maker arm is in the down position.
There is a thermostat that closes when the ice mold reaches a temperature that indicates that the water in the mold is frozen if this thermostat is faulty it will prevent the Ice Maker from going into the dump cycle.
Hope this helps.
Posted on Mar 16, 2008
SOURCE: ge monogram zd115c automatic icemaker not making ice
Unfortunately, this has been a regular problem with mine for 6 years.  It started within the first week of installation.  I suggest calling GE and keeping track of when you called, who you spoke to, etc.  Every single part has been replaced at lest once and I am still without reliable ice.  I have been asking or a replacement since day one.  GE is not good on the customer service end of things.
Posted on Sep 15, 2008
tech master
  • 120 Answers
SOURCE: GE SSS25KFMD SIDE BY SIDE
you might have a bad water valve that it wont close since your just repl ice maker then try to repl water valve at back if is leaking then the fill cup will be full of ice and also it will be over filling the ice maker mold
Posted on Oct 12, 2008
tborn6
  • 700 Answers
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
  • 10865 Answers
SOURCE: Icemaker does not make ice. Appears no water is getting to maker.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 20, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Troubleshooting a GE TPX24 icemaker
    a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
    Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
    Ge refrigeration model 20-25 icemaker not making ice
    Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
    Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
    I have a MN - TFX24PRXB - BB GE Side by side refrigerator. The Ice maker does not make ice anymore. I have tested the water valve and it is working. If I turn the gears it will start the process to...
    Check for freezer temp - if it is not 10 degrees or below the ice maker thermostat will not turn the ice maker cycle on by removing the frozen ice in tray and then refilling it for next dump cycle. And if freezer temp is high you may have leaking door gasket, dirty condenser coils, improperly operating self defroster which raises temps, low refrigerant.
    Aug 04, 2017 | GE Refrigerators
    Water not dispensing
    Most likely your water control valve on rear of refrigerator has failed. Do this pour tap water into the ice maker make sure it is on and let the water freeze. If the ice drops and does not refill then the water control valve is the problem. If ice maker does not cycle then it is the ice maker. Find your model number around the door frame and tell me which model GE you have and I will tell you the replacement parts. Let me know, Thanks, Sea Breeze
    Nov 19, 2009 | GE Refrigerators
    GE Icemaker stopped making ice. everything else
    Try these steps
    1. Check the shutoff arm
    2. Check the supply valve
    3. Inspect the water supply line
    4. Test the shutoff switch
    5. Check the freezer temperature
    6. Inspect the ejector gear
    7. Test the ejector motor
    8. Test the ice mold heater
    9. Test the holding switch
    10. Test the water inlet switch
    11. Test the thermostat
    12. Test the water inlet valve
    pls rate my suggestion.......
    Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
    GE TBX21ji Refridgerator/Freezer Factory Icemaker quit making ice
    Normally, when the temp of the icemaker gets to about 14 degrees F, the icemaker goes into the harvest mode, turning on the mold heater and attempting to eject the cubes. When the heater has warmed the mold sufficiently to release the cubes, the ejector can continue and push out the cubes, then the icemaker fills with fresh water to beging to make a batch of ice again. Manually starting the cycle as you have done only allows the cycle to start without the temp sensor seeing the 14 degrees. The mold heating generally takes a couple minutes. If your mold heater or the temp sensor are not working, you will have to replace the icemaker, as they are not available as a repair parts.
    Jul 04, 2009 | Freezers
    Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    My icemaker is overfilling and cause a chunk of ice in the bottom of the maker.
    bh, on these GE icemakers the amount of water entering the mold is controlled by temperature. There is a thermistor that sits in back by the mold. Water entering the icemaker will cause the temp. of the mold to change, effecting the resistance of the thermistor. The initial fill will activate the water valve for 5.1 seconds. After this fill there should be a 15 second delay while determining the temp of the mold. If the mold exeeds 39 degrees the fill will end and start the freeze cycle. If the temp is still below 39 degrees the control will assume there is not enough water and run the valve again for 2.5 seconds and repeat this again if the thermistor still reads below 39 degrees. Therefore Im thinking you have a thermistor problem. Im not sure if this is a serviceable part. You would have to check with GE. Catriver..post back.
    Mar 27, 2007 | GE GSH25KGR Side by Side Refrigerator
    GE GSL25JFPBS Side by Side Refrigerator Logo
    276 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
