Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Aquos screen blacks out with xbox 360 using Component Cables
I have the same issue with my Aquos 65D64U. I already bumped the resolution of the xbox to 1080i. This reduced the frequency of the "black outs", but did not eliminate them.
Downloaded the updated firmware from the sharp website to a usb drive. Placed the drive in the TV and went to the update software option on the TV menu. Since the update, I no longer get the black-outs on the screen. I also put the resolution on the 360 back up to 1080p and it works great, even through the component cables.
Posted on Jul 01, 2009
The upper left quadrant of my Sharp Aquos LC-65D64U does not display.
Check the connections of the flat cables that connects the T'Con board to LCD pane for any loose contact. Re-seat them. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
When I play a gane the sides of the screen cut off
If you have a widescreen TV, your resolution is likely the cause of this. See if your TV has a resolution setting in its menu. Don't worry if it doesn't, some TV's only have one default resolution.
Check what type of cable you are using to connect to the TV. If you are using composite cables (red, white, and yellow) and you have a flatscreen/HDTV, you should switch to component or HDMI cables. (Your Xbox may have came with component cables. They are the red, green, and blue ones, if it did and you aren't using them, use them.)
Once you're using component or HDMI, the problem should be solved. If it is not, change the resolution on the Xbox. To do this, go to System Settings > Console Settings > Display and mess around with the settings in that to find out what works for your TV.
Apr 20, 2011 | Microsoft Xbox 360 Console
I previously had my wii on an older tv and it worked fine. I recently purchased a new tv (Sharp Quatron Aquos) and when I hooked up my wii and same cables to the tv, my screen is now a hazy black and white...
You are using composite cables(red,white,yellow) mine did the same thing. The aquos is all digital, wont read analog, which is what composite cables are.
They now make a component cable for the wii. I paid $28 at b.b.
Mar 12, 2011 | Nintendo Wii Console
How do i hook up my sharp 27f543e to my Xbox 360 using component cables every time i turn the HD switch on it jumps to a static mis-colored screen.i try to change it back from 720 to 480. is it just not...
U using a stantard tube tv,that why.It is an analog tv.It can't scan in high resolutions as ur Xbox require.That,why it reverse back to the resolution it can and able to scan the lower resolutions.
Dec 04, 2010 | Sharp 27F543 TV
I have an Xbox 360, and when I got an HD tv, I got the HD cords for it and when i use the switch on the cords to go from standard tv to HD, my screen goes black and i get diagonal lines that run up the...
Either the cable you are using is no good, or there is an issue with the internal video subsystem. Try changing cables, and if possible, try a different input on your display. If the issue still exists then you may have an internal issue. The only way to diagnose this is to have your local Xbox repair center diagnose it unless you have the tools and experience to do it yourself. Certain parts of the subsystem can be replaced, but for the most part the entire system is replaced.
Mar 04, 2010 | Microsoft Xbox 360™ Premium White Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Screen Goes Blank for about 5 seconds
A friend and I both have the LC-32D64U Aquos sets with the same problem. Black screen for a few seconds with no video or sound. They came with firmware version S0804171.
Installing (reverting?) to firmware S0801101 on Sharp's website resolved these issues. Perhaps you need to update/switch firmware versions, especially if hardware replacement did not resolve the issue.
Aug 24, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
366 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
