Question about Samsung HT-Z310T Theater System
Need help with HT-z410
THE POWER WILL COME ON AND THE IT RUNS THE THE MESSAGE SCREEN IT WILL SAY NO DISK AND THEN IT WILL COME ACROSS THE MESSAGE SCREEN PROTECT THEN EVERY THING SHUTS OFF.HELP ME PLEASE
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Posted on Jul 03, 2009
My ht--z410 will no longer play movies or cds. it says no file while trying to read it or says dvd error
This either means the dvd drive went bad which I doubt but is possaible. In that case you would either need to buy a new dvd drive for it and replace it yourself or send it in for repairs. If it is not under warrenty however it probably will cost a pretty penny.
The other reason, and probably more likely one, is that whatever your trying to play on those dvds and cds is not supported by that system.
Aug 09, 2011 | Samsung HT-Z310T Theater System
HT-Z410 ~ 2 years old "chk fan" message 2 min after startup; then shuts down. Home repair? How to find new fan?
Maybe you shoulkdjust look at it to see if it's clogged up with dust. The manual says to leave 4" of clearance around the fan opening.
The manual...
http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf
Live chat with samsung might get you a part number:
http://www.samsung.com/us/support/owners/product/HT-Z410#
email support:
Call : 1-800-726-7864
Feb 05, 2011 | Samsung Audio Players & Recorders
I need help , hooking up my samsung HT-Z410 HOME THEATER, TO MY LG HDTV, SO THAT WHEN I'M WATCHING REGULAR TV THE SOUND OF THE TV CAN COME OUT TRUE THE HOME THEATER SPEAKERS, CAN IT BE DONE? CAN A COMCAST...
first of all here is a link to the manual....http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf and yes it can be conected thru your comcast but you wil need to buy probably cheapest at wallmart an RF Modulator (Less than 20 dollars) and from your cable box (vidieo out, or to tv) install the cable to the rf mod unit (ant in) and that converts it from coaxial cable to rca (meaning a cord with yellow ,red,white push on connectors) plug the red and white into aux input on surround system (see #3 on manual view on backside of surround unit)and and you got it.It your tv does not have a yellow vidieo connection (which is where the the yellow plug into tv)in the back then add a coaxial splitter after the comcast box so that the 1 coax line goes to tv and the other coax goes to the rf mod then thru RCA cables to the surround sound.you may need to buy xtra cables but they are cheap. hope i helped........you may try asking family or friends for the above equipment i described.the newer tv's dont need it and many people have this stuff layen around...good look
Jan 18, 2011 | Samsung 1000W 5.1-Ch. Home Theater System...
Hi I have a Samsung HT-Z410 system but it will not come on and I think the fuse is blown, do you know anywhere or how I can get it repaired. Please help, thanks.
if you look in your local phone directory under tv repairs you will find plenty of techs that fix stereos as well
hop it is just a fuse but remeber in most cases fuses have a good underlying reason to blow
Nov 28, 2010 | Samsung HT-Z310T Theater System
Samsung home theater HT Z410 fan chk will not stay on anymore
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Resolve this issue and it will probably stop trying to protect itself by shutting off.
Feb 08, 2010 | Audio Players & Recorders
Samsung HT-Z410: ''Disc Error''
It's not the lens. It's the bottom plate on the disk pickup. Dust gets on the rubber pieces (there are three oval shaped pads) that do not adhere properly to the disk which causes the disk to turn too slowly for the lens to read it properly. Clean those off with alcohol swabs and let dry. Also blow off all the dust in the unit since it will already be open. I have also decided to leave a disk in the player so that dust will not have a chance to get on those bumpers again. I did this last weekend and have not had problems since.
Oct 24, 2009 | Samsung HT-Z310T Theater System
Getting a "fan chk" message on my Samsung HT-TZ512
Did u ever find a solution? The room I use the home theater in gets quite hot. I use an air conditioner but I think prolonged use in the heat has ruined the fan(s). The speakers will power up, and sound can be heard but after a minute or two the CHK FAN will come across the display, and ultimately, shut the system off. Is this what happens to you? T?hanks for any and all responses!,
Ed
Oct 04, 2009 | Samsung HT-TZ512T Theater System with...
Samsung ht-z410 died. (home theater) no power
have you opened it up and checked the fuses
May 17, 2009 | Samsung HT-Z310T Theater System
I owm a samsung HT Z410 Home theater system. It plays all of the dvd movies in black and white
Sounds like you might need to change the picture output settings to your region I.e for the uk it is set to PAL
Jan 22, 2009 | Televison & Video
Samsung HT-Z310T Theater System Logo
392 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
