Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Frigidaire stand up frost proof w/ temp alarm / 98' model. Compressor running, no power problem. Removed interior panel and found that evaporator coils not getting cool. When switch for alarm is pushed on it sounds continuously. Does not even get a little cool. Possible trouble shooting tips would be appreciated. Continuity, etc....
  • dalibor skrbin
    dalibor skrbin May 11, 2010
    it seems that compressor lost compression,or gas is leaked,you must check a gas in cooling system (if you have tool for cooling systems),and check a compression.in both case you must open a system and refill it with gas.
  • 370 Answers
If your compressor is running with no freon, It should be very hot. Check if it is. And if it is and the freon has leaked out. Then you must find the leak in the system before you add more freon. If you dont this will be an ongoing problem. The freon will leak out after any length of time. This is a very hard task to find the leak, and you will be money ahead to buy another if you dont find the leak than to re charge every year or so.
Posted on Jun 30, 2009
Fridgeaire upright freezer no serial numbers to be found anywhere was trying to adjust temp on front of door outside now unit says of and is not running how to turn back on???
tough one
i guess its a frost free
turn the thermostat adjustment to on /highest temp temp ...then off /lowest
till the compressor kicks in
if not suspect faulty digital display panel or thermostat itself
agreed no serial number etc
makes it very hard to help you fix this
http://kitchen.manualsonline.com/manuals/mfg/frigidaire/frigidaire_freezer_product_list.html
Oct 11, 2016 | Frigidaire Freezers
My high temp alarm has been on all day
the warming up will be because the unit is not operational and the door hasn't been opened
call a service technician and check for a failed start/run capacitor for the compressor
the high temp alarm indicates that the food is in danger of spoiling
Sep 06, 2015 | Frigidaire White Frost Free Upright...
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire FFU14F5HW Hi-Temp alert. Checked thermistor at front panel pins 1 to 2, reading was 162.8K ohms. Removed panel to check thermistor, then put it in a cup of ice water-now reads 32.1K ohms. P
Check the internal temp with a thermometer. Anything above -12c will give you the hi alarm. Check the condenser is clean and drier not too warm, no ice build up inside the evaporator and all fans working properly etc, before suspecting thermistors.
Apr 02, 2014 | Frigidaire FFU14F5HW 13.7 cu. ft. Frost...
Upright freezer not freezing. alarm went off
check the evaporator and see if there is frost build up, also check the power to the compressor you may need to replace the overload and starter relays.if you can check the current draw on the compressor it should be 1.2 to 1.6 amps if it is not then you may need to replace the compressor.you may also need to replace the electronic control if eequipped
Sep 12, 2010 | Frigidaire Freezers
The high temp light is on, liquids are now liquid,but the meat is still frozen. I live in west central mich, and the temps have been in the high 80's and low to mid 90's with relitive high humidity, about...
Not normally,Make sure you door is sealing properly also check and make sur ethe evaporator fan is running when the freezer is in a cooling mode.you may need to remove the rear panel of the freezer and check for frost build up.if there is frost build up then defrost the evaporator with a blow dryer.
then check the continuity of the heating element and make sure it is in working order.
Aug 31, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
I have a stand alone freezer model MFU17F3GW8 serial # WB11907298 my problem is that it does not get cold enough. what could be the problem?
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Are the condenser coils on the back warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
evaporator coils are behind the rear cover inside the freezer at the bottom.
observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Compressor or freon problem will require a repairman.
Oct 15, 2009 | Freezers
Freezer control is on the highest setting and the inside temp is 40 degrees and most the food is thawed. what could be wrong?
you may have a bad compressor.also need to check the evaporator fan and see if it is turning. do you have any kind of frost build up on the back wall that you can see.the fan is located behind the rear panel in the back of the freezer if you your it running you may have a bad compressor
Sep 24, 2009 | Frigidaire 16.7 cu. ft. / 473 liter...
Freezers Logo
548 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
