Question about Westinghouse Washing Machines
Washing machine making loud noise when agitating/spinning
My old White-Westinghouse WWX433RBD1 is making a somewhat high-pitch whirring noise when agitating or spinning. When spinning, it's not able to spin the drum very fast. I disconnected the belt and it makes the same noise, so it's not coming from the pulley or the transmission. Would this mean it's the water pump? It's the only device driven directly by the motor.
  • tim8270 Jun 30, 2009
    Solved my own problem! The noise was indeed coming from the water pump. The pump was easily disconnected from the motor by slipping off two metal clips and lifting it up off the axle. This eases the removal the 2 attached hoses by allowing you to move the pump away from the hoses. Place a towel under the motor - there's a plastic drip pan between the pump and motor that drains beside the motor to protect the motor from leaks. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it fell to the outside of the basket but inside the drum, and went down the drain hose. Regarding the diminished spin cycle speed - it was diminished because the jammed pump was stealing extra force that would have transferred to the transmission. Squealing and diminished speed but working/slow drain means clogged pump.
The noise was indeed coming from the water pump. To clean the pump on this top-loader you have to unplug it, pop the top open, and remove the front face of the cabinet to expose the motor and pump. Slip off the two metal clips hugging the pump to the motor. Place a towel under the motor before detaching the hoses - there's a plastic drip pan between the pump and motor to guide the water away from the motor. Unclamp the two hoses from the pump by squeezing their spring-clamps with pliers and sliding them further down the hose. Pull the hoses off by lifting the pump off its axle and pulling it out while wiggling the hoses loose. I found a small sock jammed in the pump - it must have fallen to the outside of the basket but inside the drum during the last spin cycle, and went down the drain hose. Check the pump for damage and replace if necessary. For future troubleshooting, remember that a clogged pump causes squealing, diminished spin speed, and slow drainage.
Posted on Jun 30, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Noisy during agitate cycle whirlpool washer
Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
Kenmore 500 washer wont agitate.
Aug 07, 2013 | Kenmore 500 6952 Dryer
Will not spin loud noise
Need a full model #. Describe the noise; is it a banging, scraping, whirring, etc? Does it make the sound when it should be agitating and/or spinning? Has it run fine until this incedent?
Thanks.
Jan 07, 2013 | Washing Machines
Our whirlpool top loading washer starts making a high pitched whirring noise in the beginning of the first spin cycle. Once it gets going full speed the noise stops. What could be?
If you can hear the motor humming during the spin cycle, it could signal a defective motor drive. It's possible for the motor to fail in just one direction, which may be why you only hear it some times.
This kind of issue often requires the help of a professional. To learn more about this issue, read Washing machine will not spin but will pump and agitate. I hope this helps.
Sep 12, 2012 | Whirlpool Washing Machines
Washing Machine making a loud whirring noise when water is filling and when the machine is spinning out
Check the motor bearings If your washing machine is making a high-pitched whine or squealing noise while running, the main culprit is usually worn motor bearings. To check the motor bearings, remove the belt and run the motor by itself, listening for the noise. If it makes the noise, than the problem is most likely the result of worn motor bearings and has nothing to do with issues in the rest of the washer. Check for Obstructions Sometimes coins, bra underwires and other metal objects come loose in the wash and become stuck between the tub and the drum. Using a flashlight, take a good look inside the washing machine. If you see dents, scratches or dings, that's a sign that there either are or have been items bouncing around in there that can make a horrible racket. Check for Grease Spatter A high-pitched squealing can be caused when the grease thins around the bearing that's located under the tub. Open up the washing machine and check the interior for grease spatters or spots. That could mean that the grease has thinned out around the bearing and it's making the noise because of rubbing. Check the Drum for Irregularities Spin the drum by hand, listening for the noise. If it makes the noise in the same spot with each rotation, the problem could be with the washing machine drum itself. Parts of the drum can corrode over time, leaving it vulnerable to cracks or rust.
Aug 06, 2012 | Washing Machines
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Jun 17, 2009 | Washing Machines
Washing Machines Logo
2,124 people viewed this question
Top Westinghouse Washing Machines Experts
Mack Baxter
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
