Question about Fujitsu LifeBook E6560 Notebook
How do I remove the bios battery for the Fujitsu Lifebook N Series note book? I don't know what the bios password is, and need to get in reset it. It is model #6420.
  • 82 Answers
Procedure...
http://forums.techarena.in/portable-devices/1198300.htm
Posted on Jun 29, 2009
Lifebook p series bios password removal
Crack it open and remove the quarter size battery. that will reset the BIOS.
Jan 10, 2015 | Fujitsu FPCM24311 - LIFEBOOK P702 - Core...
Reset bios password laptops
Laptops are the same as Desktop computers. The BIOS password is usually retained by either a battery or capacitor. If it's a battery then you simply have to remove or unplug the battery. If it's a capacitor then it needs discharged, usually by connecting two pins together. You'll have to do some research on the motherboard that exists inside your specific notebook.
Please note that removing a BIOS password to access a computer that doesn't belong to you is illegal.
Jan 02, 2014 | Fujitsu LifeBook E6624 Notebook
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
How to reset BIOS password if forgot ( Fusitsu lifebook s 7110)
you will have to flash your bios to get this to work. you can do that by going to this link and fallowing directions . download the software and make sure you fallow each step careful as instructed. http://www.fooler.org/fujitsu/item/298-download-fujitsu-lifebook-s7110-bios-dos-flash-134-driver
Jun 08, 2011 | Computers & Internet
I have a Fujitsu-Siemens Lifebook e8110 which has bios password and I can not reset it. has both the administrator password and user. user password can only view the BIOS. administrator password I need to...
User and Administartor passwords are only for your OS. Windows® for Example
To reset your BIOS password, you must disconnect your laptop-battery. Wait a few minutes, and put it back in. Now your BIOS password has been reset and you can access your BIOS again.
Jun 02, 2011 | Fujitsu LifeBook E8110 Notebook
By mistake I changed my BIOS password., but I forgot it. My laptop computer is Fujitsu Lifebook series A3130 Please let me know How I do reset my BIOS security password.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Aug 19, 2010 | Fujitsu LifeBook A3130 Notebook
How can I reset the Bios-Password of my Fujitsu Siemens Lifebook C Series C1320D? Replacing the Bios-bat dosen´t work. Holding the Reset-button more than 10 sec down, while the Akku-pack is off the...
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Dec 18, 2009 | Fujitsu LifeBook C1320D Notebook
Forgot bios password
You might have to remove battery cell which is located backside of every laptop and then on your laptop try to access bios if it works then off the laptop attach the cell again in same position and enjoy bios without password.
jrpitale.
Feb 17, 2009 | Fujitsu LifeBook B2131 Notebook
Fujitsu n series n3530 lifebook
you need to open your laptop, you will find it on the motherboard, near the battery you will find the CMOS reset jumper or switch.
Oct 22, 2008 | Fujitsu Computers & Internet
Fujitsu LifeBook E6560 Notebook Logo
456 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
