Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Have a frigidaire dishwasher model #pldb 998 ac1 that will not start, the green light comes on and timer starts and decreases in time as if its working but noting is happening. is the electronic control board bad?
futureloginn
  • 734 Answers
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Posted on Dec 10, 2008
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
Posted on Jan 28, 2009
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
Waxinman
  • 56 Answers
SOURCE: Display shows PF
This is an indication that the power to the unit has been interrupted (Power Failure)
Posted on Mar 03, 2010
SOURCE: My Frigidaire dishwasher will not start.
No solution, just a big thanks about that tip on holding down that 'Heat-Dry' button. Worked like a charm.
Posted on Oct 23, 2010
Dw will not start
Hi Jana,
So I'm understanding that your Frigidaire dishwasher will not start, and that when the "ON" button is pressed it only stays lit green while your finger is on it. I would recommend giving the appliance a hard reset. You will do this by switching the circuit breaker off that the dishwasher is attached to. When you do this you will want to leave it off for 20-30 minutes. Once the 20-30 minutes has elapsed, bring power back to the dishwasher and try to restart it. If the dishwasher is not starting, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 21, 2014 | Frigidaire FFBD2409LB Dishwasher
Reset frigidaire dishwasher model FDB1100RHC
I had the same issue. I unplugged the dishwasher and plugged it back in. Bam! It's working fine now.
Oct 16, 2012 | Frigidaire Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher not working
can you give me the exact model # on your d/w? i need to see if it' has a timer or an LCD.
Sep 01, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Green light flashing, won't turn on
A blinking light, and possibly no lights, with the door closed may indicate faulty door switches (very common on newer models). Depending on the model, the switches can be removed, cleaned and put back
Jun 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Lights come on and it beeps
The timer may be stuck, you may have to change the timer.
Apr 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Dishwasher FDB956RBC0
try opening the door and closing it to see if that clears the green light
Feb 13, 2008 | Dishwashers
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
110 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
