Question about Craftsman Garden
I have a craftsman DLT 3000 with the 18.5 hp briggs intek plus. Will not start and backfires. Have drained the gas and replaced the filter. Checked the flywheel key and it looks good. Cleaned carb. but did not replace any parts. Any suggestions?
  • cstamconman1 Jun 29, 2009
    Will try again and let you know.
  • Anonymous Mar 22, 2014
    Backfires out of carb & the muffler when trying to pull cord. Checked key way on flywheel & it's good. Carb has been cleaned twice.
    Problem Solver:
  • 16 Answers
The needs a good cleaning not just empty the but remove the jet and make sure holes in jet are clear.
Posted on Jun 29, 2009
Well, I'm no Briggs expert, but I'm wondering if the spark is inconsistent or weak. Have you checked the gap? Also, you might try taking the plug out but leaving the wire on it, lashing the base to something grounded, using bare wire, and then turn it over while looking to see how bright the spark is.
I suspect these no longer use a magneto and/or points, which they did when I learned about them, so I won't try to guess what else might be wrong with the ignition. Still, it would be very quick to check for loose wires, condition of the spark plug wire, etc. I guess most of them are probably under the flywheel, though.
I'm just mentioning the above because they are easy to check. Might as well do that stuff first. I guess it's just as possible the mixture is off or something, but that's more work.
Posted on Mar 21, 2010
Craftsman LT1000 mower has muffled backfire. Mower starts fine, runs fine. At times it issues a muffled backfire- not loud at all. The backfiring continues for several moments and then disappears.
Yes, gas has a portion of ethanol in it and that contains water. You need to a stabilizer in it at the end of the summer. Drain it out and use fresh gas, add stabilizer to that as well.
The Latest in Fuel Stabilizer Technology Briggs Stratton
May 15, 2018 | Cars & Trucks
Briggs 5 hp backfires through muffler
Exhaust valve is not closing completely or the valve seat is cracked.
Sep 24, 2014 | Briggs & Stratton Briggs Stratton Intek V...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Garden Logo
988 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
