Question about Kenmore Washing Machines
During the wash cycle the agitar tries to turn and reverse but there is a definate mechanical noise and the lights in my laundry room flicker. I was told to lubricate the part connected to the transmission which reverses the gears. The spin cycle works fine. How do I get the unit open to gain access to the transmission. Thanks,
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
Hi sent you a vidieo earlier and your response was try a load on with the machine empty done that and the noise has stopped
That is excellent! Now you know that the noise is caused by the laundry in the machine being out of balance! Try distributing the laundry around the basket at first and throughout the cycles if necessary. Obviously, you shouldn't do it during wash cycles, only during spin cycles (high speed drum motion).
Jan 09, 2013 | Washing Machines
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
We moved our whirlpool duet washing machine to do some work in our laundry room. we moved it back and put a load in and it's making a loud humming noise during the cycle. what could be wrong. we turned it...
You may have dislodged the suspended innards from shock mounts that keeps some nose from escaping. I would remove the back panel and inspect the insides to see if one or more corners of the suspended assembly are now out of place.
Nov 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE top loading wash machine makes noise during agitation cycle...
look in your basket of washer see if you see anything stuck in the hole ok
Oct 20, 2017 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Dancing washing machine
if its real new as in you just installed it look behind hte unit for shipping braces that haven been removed.. they keep the machine solid in shipping and reek havok if not uninstalled
Mar 17, 2008 | Whirlpool AWM6100 Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
