Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
I have 70's 9.8 mercury motor it start with starter fluid
It starts with starting fluid but then shuts off, it won't start without starting fluid
  • 5,687 Answers
You can seize the bearings real quick with starting fluid. You found out it has spark. Now you need to find out if you are getting fuel. Some of the gas tanks have a strainer and you need to pull the gas gauge from the tank and check the bottom of the tube for the strainer. If it is clean follow the fuel line up into the motor to the fuel pump. There may be a strainer inside the pump. If this is clean reassemble everything. With the gas line disconnected from the motor pump the bulb. Use a ballpoint pin on the checkball and see if gas will flow. Reconnect everything and pump the bulb, it should remain filled and hard. Now choke the motor and pull the starter. It should try to start. Aside from fouled plugs and bad gas if it hits with starting fluid it should run.
Posted on Jun 30, 2009
How many amps are required to start a 1994 Mercury Grand Marquis LS?
How much does the starter draw or the entire vehicle,
while cranking the motor?
Jul 16, 2014 | 1994 Mercury Grand Marquis
My 2001 ford escape won't start . I checked all
Can\'t really help you with the no start problem without more information, but would advise you to stop using starting fluid right away. Starting fluid is hard on Diesel engines but they are made for much higher compression so will usually survive intermittent use of starting fluid. Gas engines just plain can\'t handle the much higher than normal compression that starting fluid produces which will destroy valves, piston rings, connecting rods, starters, ring gears on the transmission and head gaskets in short order. If you don\'t want to have to completely rebuild your gas engine don\'t use starting fluid on it ever!
May 12, 2013 | Cars & Trucks
I have a Johnson 70 outboard motor and I'm having
The moter has locked up is it 2sroke or 4sroke if 2 did you have oil in the fuel ?
Apr 29, 2013 | Boating
2003 Goldwing won't start...just one click when start button pushed
you may have blown the starter solenoid or even worst the starter motor
i cannot diagnose without seeing the bike properly
i strongly suggest you put in a workshop and get it diagnosed properly
Apr 12, 2013 | 2003 Honda GL 1800 Gold Wing
4.0 ford explorer wont start without spraying starting fluid in throttle body
could need tuneup and may want to replace fuel filter....Thing i would do first....i hate starter fluid...really ******* rings in motor.....
Aug 19, 2012 | 1995 Ford Explorer 4.0
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
My 96 crown vic police interceptor, cranks won't start without spraying starter fluid.. the car won't start without spraying starter fluid into air intake hose to carb...
starting fluid is a thing of the past. dont use it. this car doesnt have a carb, its a throttle body/ electronic fuel injection system. you most likely have a fuel pump or fuel pressure regulator issue. test the fuel pressure, should be anywheres from 35-50 psi
Oct 11, 2011 | 1996 Ford Crown Victoria
98 mercury sable runs fine but when you turn it off it may not start. let it set for a while it might start and run for some time until you shut it off and same thing happens will not start
The likely cause of this is a defective electric fuel pump, to verify buy a can of spray starting fluid at the parts store, next time it won't start remove the air hose to the engine and spray the starting fluid in, if it starts you will need to replace the fuel pump. The fuel pump is located inside the fuel tank, about a 3 hour job to replace.
Aug 25, 2011 | 1998 Mercury Sable
1992 gmc Jimmy won't start without spraying
check the fuel filter first , then the fuel pump
Jul 15, 2011 | 1992 GMC Jimmy
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
532 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
