Water is leaking from the front load door. - Washing Machines
  • emt563 Jun 29, 2009
    Kenmore HE 2 Plus
  • 221 Answers
First check the grey rubber seal for any cracks and/or holes at the bottom side. If there is any you migtht be able to turn the seal by 180 degrees to stop the leak, otherwise replace the rubber seal
Give me exact model if you need more detail how to do it.
Posted on Jun 29, 2009
Leaks water from underneath and when load is done , if you spin the drum all you hear is a bunch of water still in there somewhere, can not see water sitting in the drum
Hey mate, thats normal for these machines to have water like sound when you spin the drum. The water leaks either come from the pump, door seal or the tube between the door & heater elements. Either way you need to remove the front panels to be able to see where the leak is.
Two screws at the rear top corners & beneath the soap dish (4) to get top off.
from the inside if i remeber correctly 2 screws to remove the front panels as well as located above door your lock units.
This will allow acess to the front of the machine, remove the door itself if you wish, after the front panels come off you could put it on again (door only) and run the machine so u can see your leaking porblems.
Have fun
Jun 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
I see water down on the floor after the wash load is completed. Initially when washer starts, there is water on the ground.
Your observation of the leak is very important to confirm the point of leak. Check for leak from the door gasket on the front door, check for drain pump/valve leak, check for drain hose leak from a faulty clip.
Jan 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Water leaks from front of machine
dealng with a leak of this nature, it could be anything from a tear in the door boot (rubber peice between door and tub), a pin hole in the water pump or hoses, or a bad tub seal. Ideally you need to take the top off of the machine and run it to determine where exactly the water is coming from. One other thing to check, if you are using a detergent that suds up too much, a front load washing machine will leak around the door seal... they are designed for non-sudsing detergent.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Apr 30, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Jul 25, 2008 | LG WM-2277HW Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
305 people viewed this question
Top Washing Machines Experts
