Question about Alpine MRV-T757 Car Audio Amplifier
Is there a reset for the mrv-t757
I also have the same problem with my amp the led on the front of my amp (for the power supply) blinks orangish red if it is a problem with low ohms is there some kind of reset on the amplifer needed to be actuated once i fix the resistance problem
    Problem Solver:
  • 18 Answers
There are little black things like with 3 wires running off them.. open it up and you will see what ime talking about there black when there bad somtimes the wire burns off u can check the model number on em and solder new ones in thats whta i had to do to mine and it works like a charm now.. i had a hard time finding the number on the burn ones because it blacked it out. so i checked other ones for model number and wala..
Posted on Dec 05, 2009
  • ncarlson187 Jan 24, 2012
    Couldn't find in mine?
I know this already. I need to know where to find the problem.
Posted on May 26, 2009
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Generally when you have all your connections sorted disconnect the power and reconnect once all other wiring is complete,if the red light comes back on its more than likely there is other problems.
Posted on Apr 20, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
3 Reset System
From the remote, press
<MENU> <1-2-3>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
All customer settings are
reset to factory default.
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I have a problem .. I have a mrv t757 amp and it isnt bumping like I used too .. If i keep the volume low all 3 lights are green but once I turn it up it blinks red n yellow n green back andn for in the...
check all your connections to make sure you don't have a short, but most likely it's your amp. If it was the battery it would turn on and off, including radio, then your car wouldn't start(dead battery), but if it does this and your car turns on no problem then it sounds like the amp gave out.
Aug 23, 2011 | Car Audio & Video
have you tried removing the power from your amp, there are several reason to put an amp in protection mode, its usually due to incorrect wiring. ohms law???
Sep 11, 2010 | Alpine MRV-T757 Car Audio Amplifier
Alpine MRV-T757: Protection and Music light lite up green and Battery light Flashes Red? Do you know my problem?
check all of you connections especially the earth at the amp and the body of the car
Aug 12, 2010 | Alpine Car Audio & Video
The light power is red and it smell like melt
on an amplifier that usually means that its burnt out, or that you've melted one of the wires. check the ground wires and whatever you have the amp sitting on. if everything looks alrite then its most likely the inside of the amp is fried.
Jun 20, 2010 | Alpine MRV-T757 Car Audio Amplifier
Red protection light on when power,d up from battrie is this normal
check the connector at the amp and make sure the wires aint touching also check ur speaker wire are rigged up right... do not run 2 subs off 1 channel as it will pop fuses and the procet light will come on
Oct 21, 2009 | Alpine MRV-T757 Car Audio Amplifier
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Alpine mrv-t757
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Oct 18, 2007 | Alpine MRV-T757 Car Audio Amplifier
Car Audio & Video Logo
367 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
