Question about Whirlpool Microwave Ovens
How do you install a door handle on a whirlpool microwave. I have a replacement handle but no instructions.
  • 1 more comment
  • jwrush49 Jul 02, 2009
    The model # MH1150XMT-0 Whirlpool. Is the solution still the same....dont want to start hacking and really make a mess.
    Thanks....
    John Rush
  • jwrush49 Jul 08, 2009
    Nope....took off the inside strip....and it was a *****...only to find that no screw heads were there. The inner part of the door perimeter is surrounded by what looks like a row of teeth that are welded to the door frame. I can see no way to remove this "frame" and get at the screw heads for the handle.
    Any suggestions?
    John Rush
  • jwrush49 Jul 15, 2009
    WOW....I feel like I am diffusing a nuclear bomb!
    There are only two screws in the whole door....and they are on the side of the door by the handle. I will give your idea a shot...let you know how it works.
    John Rush
    President:
  • 1,136 Answers
Hi, I am sending you a picture of the door in hopes that it will let you see how to get to the handle screw.Unforunatly it looks like the door needs to be disassembled quite a bit.
I hope this helps. I will be here for a while so please let me know if I can sssist you further.
Posted on Jul 08, 2009
  • 4 more comments
  • Victor
    Victor Jul 08, 2009
    See if there are screws under the door frame as well. I think the door hinge bolts and the screw #9 play a roll in holding part of the door together. Try and use a flat blade between the edge where the #9 srew is and the inner door frame and see if it might pry apart. PLEASE be carefull and not force the issue to hard. I have changed a few and these ideas I am giving you seem to be familiar step I took to seperate the door/
    Vic
  • Victor
    Victor Jul 09, 2009
    Hi John,
    Was this helpfull at all?
    VIc
  • Victor
    Victor Jul 15, 2009
    Hi, I hope your repair went well. Could you let me know if I was able to help you at all?
    Thanks
    Vic
  • Victor
    Victor Jul 15, 2009
    Ok Thanks John.
  • Victor
    Victor Jul 15, 2009
    I think the deffuesing a bomb would be easier............
  • Victor
    Victor Jul 22, 2009
    Hi John, Were you able to get the handle on? I just put a handle on yesterday and I found there were plastic clips holding the outer part of the door locked to the metal frame work of the door. I had to pry the clips away from the frame while pulling the frame with the other hand. There wer 2 clips on each four sides.
    Please let me know.
    Thanks You
    Vic
  • 999 Answers
The thin plastic strip around the inside of the door comes out. You have to be careful as it breaks pretty easily. It is just snapped in place. the handle screws are behind that. Ask me any questions and the model number would be a help. Eric
Posted on Jul 02, 2009
  • Eric Duda
    Eric Duda Jul 02, 2009
    Yes those instructions will work. Here is a picture of the door assembly
    http://www.searspartsdirect.com/partsdir...
    Eric
  • Eric Duda
    Eric Duda Jul 07, 2009
    Hi John,
    Did you get the handle on ok?
    Eric
  • 3,230 Answers
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
This is a common way to do this....
Good Luck!!
Thanks
Posted on Jun 29, 2009
How to replace handle
This is a difficult thing to explain in the text forum to change. Go to Youtube or RepairClinic to see videos to make this easier for you. Whirlpool microwave door handle replacement Door Handle Replacement part WB15X10249 GE Microwave Repair
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 01, 2014 | Frigidaire FFMV162LW Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Need to replace door handle
1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it. 4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame. 6. Starting at the top right corner, pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later. 7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE: When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components. 8. To remove the door switch actuators from the choke, remove the screw from each actuator. REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
Read more: http://www.appliancepartspros.com/whirlpool-microwave-door-handle-w10246505-ap4418092.html#qa1#ixzz2qpA2P5CA
Jan 17, 2014 | Whirlpool MH3184XP Microwave Oven
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Handle replacement
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
I hope this helps you.
Mar 17, 2010 | Whirlpool GH4155XP Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
Replacing door handle of Whirlpool GH6178XP
I kept prying on the frame case until it disengaged, came loose and exposed the bottom screw.
Feb 17, 2009 | Whirlpool GH6178XPS Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
