Question about Car Audio & Video
Newer radio not working
I have just removed the original radio cassette player to fit a newer panasonic with wires and no connectors. I have left the car loom as is, and conneceted the wires or so i thought but it keeps blowing the fuse every time i connect the battery can you please help?? (ive made sure there are no touching wires )
    Problem Solver:
  • 9 Answers
Back-up and ONLY connect your red yellow and black wires. Are you still blowing fuses? NO? good... next check your illumination and dimmer wires (the orange and orange/white) if those get mixed up, you will also blow fuses.
IF you blow fuses with only those 3 wires connected, it's likely you have something exposed and touching.
Posted on Jun 29, 2009
I have just bought a boat which has a alpine 7618r fitted but its not working can i slide a moden cd/mp3/usb replacement unit in there using existing wiring /speaker loom
Yes you can replace that unit however the harness that plugs into the old alpine in all probability will not work with another radio so you will have to connect the new radio's wiring harness to the boat's harness.
Aug 17, 2016 | Alpine 7618r Audiophile Car Headunit Tape...
I have a 2004 freestar s with a factory am/fm radio. i installed an am/fm/cd radio. it will not recognize cd's in the player. tho original radio has only 1 plug port, the new radio has 2 ports. is the...
is it a new cd/radio ? the wiring is the same for a radio with or with out a cd player , the cd should work once the radio is connected , the other port you mention may be relevent as the original radio was a factory installed , these are usually designed to be useless to be used in other vehicles as a theft deterrent , i would remove the new radio and have a good search in the radio space as there may well be the second connector you require , be very carefull as there are many sharp edges and the apeture is not very large , the second connector , if there, will most likely be taped to another loom so as to keep it away from touching other parts so a good torch and have a search , keep me posted if you wish
Mar 11, 2015 | 2004 Ford Freestar
How to take the radio out and replace it with a cd player
hello,depending on your particular vehicle,as there are a few different ways to remove the radio fitted as standard,but most are usually removed from the dashboard with a 'radio removal' tool,a specially formed thin hooks that are inserted in to the left and right of the radio through tiny slot's,and pressed outwards to unclip the 'locking' mechanism that prevents unwanted removal.fitting a cd player is quite easy,as you can normally get a standard ISO adapter that will fit in to your car's original wiring plug,and then you just simply plug the other end in to your cd player,but you may have to specify to a local radio stockist of your specific vehicle and year of manufacture,as there are quite a few different adapters available,failing that,an auto electrician can usually fit a car radio in about 15 minutes,often without a wiring diagram,so can be quite cost effective to enlist the work to a specialist.hope that helps, cheers.
Oct 17, 2014 | Cars & Trucks
Will the pioneer deh p3100ub fit a 92 civic?
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 Models
See Figure 4
Removing the radio will require removal of the front part of the center console.
The original equipment radio has a coded theft protection circuit. Before beginning removal, be sure to know the code for re-installation. The code is erased whenever the battery is disconnected or the No. 32 (7.5A) fuse from the under hood fuse/relay box is removed. When power is re-connected, the word "CODE" will be displayed and will require entry of the 5-digit code for that particular unit.
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Disable the SRS system as described in this section.
  2. Remove the center instrument panel by removing the four philips screws on the top and sides.
  3. Disconnect the 4-pin connector from the cigarette lighter.
  4. Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
  5. Carefully pull the radio/cassette player out.
To Install:
  1. Plug in the 16 pin connector and install the two retaining screws.
  2. Plug in the antenna lead, the cigarette lighter and carefully install the unit.
  3. Install the center instrument panel. Re-connect power to the car, and enter the 5-digit theft protection code for the radio/cassette player.
  4. Enable the SRS system.
Aug 14, 2011 | Pioneer DEH-1700 CD Player
Hi im putting in a JVC cd/radio in a 1997 ford escort TD,Ive removed factory fitted Ford radio cassette,leaving 5 wires connected to a yellow plug,I have 3 wires coming out of JVC marked yellow memory back...
hi...well i know this might not be of any help, but you can buy a connector that plugs straight into the ford plug, and then you plug the jvc plug/s into that, not cutting wires no messing up the original connector just incase you want to sell the car with original system in it... http://productfinder.autoleads.co.uk/productinfo.aspx?&m=FORD&f=ESCORT&id=463&pID=6889
thats the link for it...if you tell me what colours are on the ford plug i could tell you what goes where...thanks
Feb 04, 2011 | 1995 Ford Escort
I need a ac adapter for a Sony WM-FX193fp Walkman
Any +3vdc source with a positive center conductor will work if it fits.
Suppliers like Radio Shack would have power supplies and adapters to make them fit a variety of connectors.
EBay lists a zillion of them
http://desc.shop.ebay.com/Gadgets-/14948/i.html?LH_TitleDesc=1&_nkw=3v+ac+adapter+sony&_catref=1&_fln=1&_trksid=p3286.c0.m282
Feb 01, 2011 | Sony Walkman WM-FX193 Personal Cassette...
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
Mar 12, 2010 | 1992 Ford Probe
Jensen cr220x wiring
contact me at adam_64_@hotmail.com I have the same stereo and I have it wired... with the stock connector..
I'll chase the pins down for ya... just contact me.
this 60 watt deck is AMAZING..
Jun 05, 2009 | Jensen SCR-60 Stereo Cassette Player with...
Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Jun 03, 2009 | 2006 Subaru Forester
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
