Question about Trendware TEW-231BRP Wireless Router (tew231brp)
Constantly dropping connection
I have a Trendware TEW-231BRP Wireless Router. I get a good to very good connection but it keeps dropping the signal. What can I do?
  • 60 Answers
How many computer experience this problem? You can try playing around with the channel on the router, use 1, 6 or 11 and move the antenna.
Posted on Jun 30, 2009
I installed the linksys monitor and that seems to help. I still loose the signal but seem to get it back sooner. I think the router is just weak and will upgrade to a linksys router in the future
Posted on Jul 01, 2009
Why do I keep losing internet connection?
your device is to far away from the router, your got to much material in the way blocking the signals, or you have some type of electrical signal interfering the wifi signals.
Apr 25, 2014 | Trendware TRENDnet TEW-432BRP 54Mbps...
We havea TRENDnet Wireless AP TEW-430APB - keeps dropping wireless
It can drop signal if there are other devices working in 2.4GHz band interfering with it. Try to switch over to 5GHz band.
Aug 29, 2017 | Trendnet TEW-430APB Wireless Access Point...
Hello. I have a TEW-432BRP D1.3R and I usually get close to 10 minutes of connection then it drops the connection and I can't browse the internet. I have to turn the power off and wait 15-20 seconds...
First, check to see if the connection to the TEW-432BRP is not what is dropping signal. If the ethernet line is functioning and you don't lose connection, re-attach the router and try performing a factory default reset on the device. Otherwise, you may want to contact Trendnet support for assistance in determining if the router is faulty. From a hardware standpoint, there are several things on the mainboard of the router that could cause your symptom.
Nov 29, 2017 | Trendware TEW-432BRP Wireless Router...
All of the lights are ON but i cannot receive any wireless signal. all of the ports are working by connecting to my pc through the cable. everything works except no wireless signal even wireless light is...
It sounds like you need to update your firmware on your router you will want to keep your router directly plugged into your computer in order to do so here is a direct link to download firmware
http://www.trendnet.com/asp/download_manager/list_subcategory.asp?SUBTYPE_ID=1043
This is the firmware version 2.00 good luck
Nov 29, 2010 | Trendware TEW-432BRP Wireless Router...
Trendnet losing signal all the time. No idea why?
my suggestions is replace it..its damage already
Jun 24, 2010 | Trendware TEW-652BRP Router
I lost my trendnet router tew 231brp password
You can reset the router by pressing the reset button with a paperclip. The button should be by the antenna. You have to press it an hold it for about 15-20 seconds to reload the router to the factory defaults. Then you can login with the default password and set up the wireless again.
the factory default password for the router login should be admin both for username and for password.
Jun 19, 2010 | Trendware TRENDNET TEW-423PI Wireless...
How I can reset the password? I do not remember it
You must remove all power from router, and press the reset button, this will return the unit to factory spec's then you can login, as default, and re-setup the router.
downloads.trendnet.ru/TEW-231BRP/Manual/QIG_TEW-231BRP_EN.pdf
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=869&SUBMIT=Go
All in these manuals above..
Apr 09, 2010 | Trendware TEW-231BRP Wireless Router...
Frequent disconnection using wireless router
if you live in a heavily populated area you might be experiencing interference try switching the wireless channel on the routers config page. if there's a choice for auto-channel try that.
Jun 28, 2017 | Trendware TEW-432BRP Router (S4432514)
Router failed
I assume that all lights are on as normal on the router.
Check the System light.
SYSTEM
This indicator blinks green means the Internet Broadband Router is
working successful. Otherwise, this indicator always on or off means the function of the Internet Broadband Router is in a fail state.
If the System light is either always on or off go to step 3 below, otherwise start at step 1.
1. power down router and wait 30 seconds and power up.
Try connecting via 192.168.1.1 then 192.168.0.1 if NO do step 2.
2. disable any firewall programs on the PC
Try connecting via 192.168.1.1 then 192.168.0.1 if NO do step 3.
3. do a factory reset of the router. on the rear panel of the router there should be a small hole with a small button maarked RESET. if you press this in for 10 seconds it should RESET router to FACTORY settings.
Try connecting via 192.168.1.1 and 192.168.0.1 if NO then the router firmware is possibly corrupt or there is some other hardware fault.
Jul 18, 2008 | Trendware TRENDnet TEW-443PI 108Mbps...
Trendware TEW-231BRP Wireless Router (tew231brp) Logo
114 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
