Question about Kenmore 64802 Top Freezer Refrigerator
Water leaking into refrigerator & under vegetable bins
Can you tell me exactly where this hose is located on the refrigerator? we have been trying to locate it as well to try to clean it.
  • 82 Answers
Generally the condensing water leak in a dish above motor (compressor), wen evaporate from the heat generated here...
You can try to locate the hose here and blowing with something to 'clean' the clogged hose.
Posted on Jun 29, 2009
Ge profile refrigerator water under vegetable bins
Most likely defrost drain is clogged
Nov 13, 2017 | GE Refrigerators
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Refrigerator leaking water
You gave no manufacturer name or model number so this is only a guess: If you refrigerator is a self defrosting one, it will periodically, allow ice building up in it to turn to water which naturally drips to the lowest point. Most refrigerators have a drain below the vegetable bins on the bottom. That is probably where the water is coming from. Solutions include putting a shallow baking pan under the bins or under the refrigerator to catch the water, then empty it periodically.
Jan 21, 2013 | Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
Water accumulates under vegetable bin (bottom of refrigerator) every couple of days
If this is an older style top mount refrigerator than most likely the drain is clogged causing the water to leak into the fridge during the defrost process. What's the model number?
Jul 06, 2011 | Refrigerators
My whirlpool is leaking water under the vegetable/fruit bins and inside the cheese/meat bin.
defrost it, remove back panel on freezer side, and unclog small hole where water collects
Feb 13, 2010 | Refrigerators
GE refrigerator leaks water under the vegetable and fruit bins
If the refrigerator is of the frost free type, and most all are today, the unit has a defrost cycle where the compressor is shutdown and a heater comes on to melt the ice buildup on the evaporator coil. This water has to go from a drip pan under the evaporator coil down a rubberized or plastic tube to another pan at the bottom of the fridge where it evaporates. Either this hose is blocked or the opening to the hose is blocked. Find the hose (usually on the back of the unit) and run a long wire with a small piece of cloth attached to the end of the wire to get it flowing again. Your water in the veggies comes from the overflow of the upper pan into the inside of the fridge.
Jun 26, 2009 | Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
306 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
