Question about Garmin GPS
I have Garmin Street Pilot c330 purchased 12/2006. Tried to use it in last few days, and can't get it to respond, as though battery is dead. Plugged into power source in car for 3 hours (while travelling) and still had no power.
  • 583 Answers
Sometimes the internal circuit board moisturises and needs to be heated up for longer period to power up.--try plugging in with power for minimum 7-8 hours and check. if it doesnot power up after that too,then it indicates that the internal board is rusted and mistracked due to rust. in that case the unit needs to be opened cleaned an junctions to be resoldered and checked properly.its a common issue and gets solved in most cases.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 29, 2009
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen says low battery, then goes blank. can I get a new battery?
Yes, you can replace the battery. Please view video at link; http://www.videojug.com/film/how-to-replace-your-garmin-street-pilot-c330-battery-2
And also see link to purchase battery.
http://www.newpower99.com/Battery_for_Garmin_StreetPilot_c330_p/garmin%20streetpilot%20c330.htm
Please let me know if it helps.
Thanks
Apr 26, 2010 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Pull the face off try to reset it, if it will not reset, or work in the car or the house, the battery needs swapping out,
Garmin $100
Regards
Jun 21, 2009 | Garmin StreetPilot C330 GPS Receiver
How do I change the battery in a Garmin Street Pilot C330
Sep 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Street pilot is dead
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Dead battery on Garmin Street Pilot C330 - Who can fix this?
My Garmin c330 just died and wouldn't come on when I plugged it in. I tried the reset button after taking off the face plate with fingernail right where it says garmin. Then I plugged in computer with usb and it worked. I will try in car, but the problem might be the fuse in car charger, I looked in manual and it shows how to replace. So I will go to radioshack to get new fuse.
Aug 22, 2008 | Garmin GPS
Garmin street pilot c330 instruction manuel
The instruction manual is available to download from Garmin's website, www.garmin.com. Click on the StreetPilot C330, then go to updates and downloads. You should find the manual there.
Mar 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 330 street pilot keeps shutting down, only had it 1 year
Have you tried charging the unit on the computer? If not, try doing this for a few hours. Sometimes it can help.
Nov 04, 2007 | Garmin StreetPilot C330 GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
18 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
